Intake grate question
Results 1 to 14 of 17
    Default Intake grate question
    I've been wondering..Is it neccessary for the rear of the intake loader grate to rest upon the surface of the intake at the back? Or is it OK to have the rear suspended with only the four mount bolts securing the grate. thanks
    Morgan Hill
    Quote Originally Posted by zombie View Post
    I would not feel comfortable with just the mount pad holding the grate in place unless the bolts were enormous.
    There is a huge amount of strain on those grates. Why does it not touch the intake at the rear? Something is not right....
    GT (Not Gary Taylor )
    GT
    Zombie pics might help , some there were some variations in some of the stock rock grates respective to the rear , my loaders for example are designed to "rest" in the shoe casting area Tom
    To race your berkeley jet boat in NJBA, you must have grade 8 bolts with locknuts. So I drill and tap the threads to 5/15th and put locknuts on them. Never had a problem. Pat
    Thanks for the input. I was test fitting an extra blocker grate and noticed no contact in the back by about 3/16" or so. I can weld it up and then grind it to touch. With the four 5/16" grade 8 bolts I thought maybe it was not necessary to touch.
    Shell Knob, MO
    At high speeds, those loaders can vibirate quite a bit if they are not secure at the back. I've even seen boats gain MPH from bolting them down back there. I would not be comfortable with a loose loader rear end on a very fast boat.
    Ladera Ranch
    Duane if they just touch is that okay or do you recommend bolting through the intake? Boat is a 21 footer in the high 80's if it matters.
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Watch that drill depth!!!
    I vented my oil pan when I drilled and tapped. Ouch!
    Loose, the Dogs of War!
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Quote Originally Posted by Schi-502 View Post
    At least the tapp went in easy huh
    That would ruin my day to say the least
    It did. The last to be drilled. On my back in AB gravel, arms tired. Just wanted to be done. WTF, where's this oil coming from? AAHHH Schizat!
    I'll remember it well.
    Jet boat service
    Sebastopol Cal.
    My white lightning top loaders don't touch the housing on the back side but they do have a fifth mounting point drilled on the rear brace so you can bolt up the back side with a washer thick shim if you are running high speeds. You need to drill and tap the intake. jim
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    are yours the cast aluminum loaders
    Bullhead City, AZ
    Quote Originally Posted by 78CoLeBBF View Post
    http://www.performancejet.com/whitelighteningNEW.htm
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Jet boat service
    Sebastopol Cal.
    Thanks Thunder.... Jim
