No water
Results 1 to 14 of 20
No water
    Bullhead city AZ
    Default No water
    I tried to run the boat on the hose today and i wasnt getting anything out the dump line, was flowing out the pump fine.....
    I didnt turn the hose up all the way, should i try more pressure? Im running a presure reliefe valve, but i wouldnt think it would stop the flow and if it did, it would dump it out the side....
    Should i try again with more pressure...
    the river is 2 min from my pad, but dont want to load up for this little run
    Done.... So.Bay*310*'s Avatar
    So.Cal
    Steve-Crank the pressure all the way up. I just ran mine last night. Had to do the same. Run the motor first...obviously, then crank the hose up all the way. Is this concern on the Caribbean?
    No Longer Recovering 454Rocket's Avatar
    Torrance, CA - Havasu, AZ
    Did you make sure your lines are clear??
    Tacoma Wa
    You crank that hose too high and you can force water past your head gaskets. Be careful. Had to rebuild a jet ski motor cause the hose had too much pressure.
    Bullhead city AZ
    Quote Originally Posted by So.Bay*310* View Post
    yes , thanks Nandi
    Bullhead city AZ
    Quote Originally Posted by 454Rocket View Post
    Yes they are, all brand new lines & fittings
    Bullhead city AZ
    Ok were good to go now, i have to be smarter then the average bear
    I just shut off the pump and got all kind of water flowing thru the hull
    Thanks .......
    So.Cal
    Quote Originally Posted by LuckyDaze View Post
    If i'm not mistaken, an average hose pressure only flows 10psi plus. I put a pressure guage to my motor and ran water to it and only read 10psi water flow. I was trying to get near ballpark when pre-setting my pressure regulator on the trailer. Might have been a weak water pressure though.
    Its all in the pan
    Norco
    Your mistaken. Most house water pressure regulators are well above 10 psi. Mine is set at 65. I have 120 coming up the main. Gotta love Norco water pressure!!!!!
    Senior Member tahitijet's Avatar
    40-60 is average.. can be more or less though.
    So.Cal
    Damn....must of had weak ass pressure up in Bullheadredneckville! hahaha
    Bullhead City, AZ
    Steve if you need any help I will make myself available tomorrow, just let me know.
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Wet
    Wet is offline
    East Hampton, CT
    We're way over 10. I haven't had water pressure like this in a long time. The hose will do the "Cobra Snake" dance at full tilt.
