Do you use and air filter?
Results 1 to 12 of 12
    Senior Member tahitijet's Avatar
    Default Do you use and air filter?
    I just switched from my dan olsen alumn. scoop to a fiberglass scoop. with the olsen scoop i did not run a filter but it was sealed up tight for the road.
    with the new scoop the tray doesn't seal 100%. So are you guys running a air filter inside the tray? or just stuffing the scoop when your hitting the road?
    Yucaipa Ca
    I just stuff it with a towel.....
    Senior Member wajetboy's Avatar
    Auburn, WA
    towel here also
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    Denton, TX
    I made an aluminum plug.
    thats what i was thinking to, I assume you have foam glued to the back of the alumn?
    what about on the bottom? my tray has a small gap at each corner and also 4 small holes cut for the float adjusters to fit through.
    Quote Originally Posted by Btnhtillidie View Post
    KN Air filters or CG flame arrestors
    Senior Member bp298's Avatar
    LHC
    here's mine. not especially pretty, but when you're towin through dirty dusty pits and staging lanes, launching/retrieving 10-20 times a weekend, functional enough to keep the carbs and engine clean...
    i can't match the numbers on these things when searching the k&n online catalog, because i got these things 14 years ago. but i -think- the e-3403 would fit, although it would be snug...
    Charlotte, NC.
    Did those two peices come as one unit?
    Rancho Cordova. CA
    I run K&N's in my scoop too.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    k-n also
    Norco
    K&N CC approved, Closed hatch
    LHC
    ohellno... the spark arrestors were on the boat when i bought it. i just hunted to find some k&n's that would snugly fit over them. on my previous boat, i ran the uscg k&n, but that wouldn't this setup with the scoop, so i just improvised. i ran these in both the old dooley scoop, and the taller glass scoop...
