jet suction psi connection
Results 1 to 7 of 7
    FLAGSTAFF AZ.
    Default jet suction psi connection
    Can anyone tell me where to tap a fitting on the suction of a 12 berk to read suction psi
Name:	jet boat rooster 026.jpg
    SLOW MEMBER slowboy's Avatar
    Duluth, MN
    If you are going to only use one pressure port, I think it is best on the side of the pump suction housing, one inch ahead of the impeller. I think alot of racers, test there, as well as on the top.
    I went 1 high and 1 low, right now my upper port is reading 13 psi higher than the bottom. I still have a little loader left below the keel though.....in fact I think that's on my todo list for today.
    Silverdale, Washington
    One high and one low here as well. Haven't got the boat wet yet though.
    FLAGSTAFF AZ.
    Default psi
    thank you for the help looks like 1/4 npt correct
Name:	1979 tahiti 004.jpg
    If memory serves me correct,mine are 1/8"npt.
    1/8" NPT to -4 AN for me here
