air in the bowl????
Results 1 to 11 of 11
air in the bowl????
    2 miles from the water ahhell's Avatar
    Fort Mohave
    Question air in the bowl????
    yesterday out on the lake boats running fine, stop in a cove for +/- hour idle out, hit it and tach goes to 5000 and boat doesnt move too much at all, so I back and and slowly accelerate and still seems to be "slipping" but gradually planes and scoots along. Couple miles later come to idle, try hitting it again....same thing
    This has happened in the past but ususally clears after initial plane...any ideas???
    thanks, Bob
    Engine junkie
    Thermal, CA
    You have weeds stuck in the grate or wrapped tight around the shaft, could be rope too.
    Life's journey is not to arrive at the grave safely in well preserved body, but rather to skid in sideways, totally worn out, shouting"....holy shit.... what a ride!"
    Fort Mohave
    I'll go check again, but I didnt see/feel anything
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    If you find its air in the bowl being a problem Duane at Hi-Tech sells the solution to that problem called the prime a jet
    http://www.hi-techperformance.com/HPParts.HTM
    Laps Timed By Sundial halcyon days's Avatar
    Quote Originally Posted by ahhell View Post
    hit it and tach goes to 5000 and boat doesnt move too much at all, so I back and and slowly accelerate and still seems to be "slipping" but gradually planes and scoots along....any ideas???
    thanks, Bob
    My jet will do that on first start-up after sliding boat off trailer, just tilt diverter up & let air out.
    Fonz69, thats a COOL idea.
    Co-Founder of SHB MarKist's Avatar
    it might be a rock stuck in your bowl vane , saw that happen with a buddies boat stuck a coat hanger in from the diverter side and pushed it out ( we were at the lake )quick fix...
    Markist
    "Life is SO much better now......
    Quote Originally Posted by halcyon days View Post
    yeah, untill something gets stuck in IT, and it sprays water all over your freshley polish aluminum that you worked all week polishing!
    been there done that!
    Markist
    Frozen Tundra, WI
    Used one on my last boat and it worked great
    Stay off the beach or out of the sandbars might help
    Fort Mohave
    Quote Originally Posted by Fonz69 View Post
    got under it, looked in the cleanout, ran rubber hose thru divrter and all blades and nada...guess I'll be going back to the lake to test it
    sorry.. no cigar here
    the water is full of tiny particals that will go right in that thing exspecially if it floats (grass, sticks, ect.)
    oh and BTW I like it to have air when I first start it up, it like its gotta a stallconverter in it.. works for me!
    Markist
    Fort Mohave
    musta been air, just got back from Lake Mohave and it was GLASS, also did near record speed (for me) of 52...guess I'll just have to burp her occasionally
    Thinking about it the wind was up yesterday and I was airborne 2-3 times may have contributed to the problem???
    Thanks for the input
