fuel fill hose
Results 1 to 9 of 9
fuel fill hose
    blown mopar moparjet's Avatar
    manassas,va
    Default fuel fill hose
    what kind of hose do you guys use for the fuel filler cap to tank. and where can i get some?
    throw it in reverse
    Southwest corner AR
    Jet Boat Performance should have it! Or you can try your local boat center! NAPA carries it but will have to order it! WT
    WT
    WFL Crew!!!
    Senior Member tahitijet's Avatar
    napa has fuel fill hose in stock usually.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Last i used the fuel stuff with a metal coil in it. It wouldnt flex and the fuel fill ended up shaving off shards of rubber into my fuel tank and eventually leaked. THis time i went with some standard plumbing hose from lowes, it's there 2" coupler deal with indentions for hose clamps and everything, fit perfect and is soft enough to flex when needed. We'll see how that goes..
    Southwest corner AR
    FYI Rubber and Gas don't mix! I hope you made sure it is for gas or it will go to [email protected]&t quick! WT
    WT
    WFL Crew!!!
    Newton Ks.
    Auto-Zone, 1 1/4 fuel hose was the size I think for mine, about a Buck An Inch pricewise.
    H.L. Mencken
    The Earth
    Blog Entries
    24
    There are softwall and hardwall versions of the marine fuel fill hose. You should make sure you get marine hose. If you ever have a problem with a fire or something and you've used unapproved hose..... well... result might not be the best.
    San Clemente, Ca
    There are
    softwall
    and
    hardwall
    Is the 2" softwall a OD and ID measurement?
    The Earth
    Blog Entries
    24
    All the hose is ID measurement.
