20w-50
Results 1 to 8 of 8
20w-50
    Default 20w-50
    you guys running this oil what is your oil pressure at after its warm.
    mine never dropped below 70psi,which makes me wonder if its pushing the oil through it.
    doesn't the oil pump have a pressure relief at 70psi
    i would feel better if the gauge was reading 65psi
    Senior Member hotbo's Avatar
    lake Ouachita AR
    i run 20-50 and engine temp at 180 degrees at idle in my bbc is 45-50 psi at wot around 70 ,melling highvolume,lowpressure pump.travis
    p.s has been this way since last re-ring 3 years ago.must be a good one.lol!!!!
    Member BadBahner's Avatar
    Apr 2009
    Quote Originally Posted by carveronline View Post
    I run 20-50 and my engine water temp is 110 and oil press is 40-50
    BadBahner
    1981 Bahner 19 Bubbledeck 454 12jg
    2009 HTM SR-24
    yea my temp is only 130-140 but never drops below 70psi should i run something different
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    The gauge never drops below 70? Maybe something's wrong with the gauge... try priming the pump and see what the
    gauge reads, you should be able to drop the pressure by slowing the drill down. You could actually probably just kill the ignition and turn the motor over for a while too.
    Newton Ks.
    Used to run 20-50 Castrol Synthetic, hard to find lately so running 10-50 same.
    Stock GM/Melling oil pump, 23psi hot @ idle after a 4 or 5 mile WOT rip, engine cooling water running about 130*, 58PSI @ full throttle (5,400 rpm).
    H.L. Mencken
    turning the engine over with the coil disconnected i got 55-60psi (cold)
    and the gauge build pressure turning it over with the key
