holley question
Results 1 to 12 of 12
holley question
    AIR POWER TAPPED OUT's Avatar
    Las Vegas NV - Big River CA
    Default holley question
    This may sound stupid but I dont know. Someone told me that a holleydp can only go on the intake one way with the secondarys toward the back of the engine is this true???
    Charlotte, NC.
    Quote Originally Posted by TAPPED OUT View Post
    I dont see why it would not work but i dont know. I will say the bolt holes will line up so you could secure it.
    Colfax, Ca
    For some reason, I don't believe that statement
    Have even seen them mounted backwards on some engines, they will run fine. For very hard accelleration, you may encounter some issues, and need to change to a different style float for sideways carbs, or jet extensions for the secondaries of the inline carbs.
    Senior Member VAMI's Avatar
    srq,florida
    FE daul quads fords had them reversed.All the engine knows is air and gas is coming in.
    I figured this guy was full of shat. I had to prove it.
    San Diego, CA
    The carb can be mounted any direction you would like, just adjust float levels accordingly. Heck you can mount them diagonal if you have an old edelbrock manifold single plane manifold. I have this one just for a nostalgia motor I'll build some day.
    Boat 405.
    Run them every which way but upside down , have run them backwards However as suggested above on hard accell the fuel in the "rear" (front bowl) will tend to run away from the jets with out mods Tom
    Wade & Denise Miss Venomous's Avatar
    Simi Valley, CA
    Wow ! Very nice indeed....
    <img src=http://www.performanceboats.com//signaturepics/sigpic2032_1.gif border=0 alt= />
    "Sunday Beers Are The Best" RIP...
    Quote Originally Posted by Miss Venomous View Post
    Hey Glad you discovered there really is a "Jet section"
    Default Suckers
    Yeah Tom, but jets still SUCK, even in the jets section.........Suck and blow, suck and blow.......Ray
    LOUD BOATS SAVE LIVES
    ok ill whore another holley thread. this weekend im doing a rebuild kit on my 600. i believe the previous owner used some spray chrome on it. after the solvent gets rid of the paint, is there a way to keep the carb lookin good?
