Building a 502 your thoughts
Results 1 to 8 of 8
    Senior Member Cobra 02's Avatar
    Montclair
    Default Building a 502 your thoughts
    Just bought a GM factory 502" (4.466 x 4.00 )(9.80 Deck) short block ( just Block & Pistons) and installing it into a 2110 open bow approx:2250 pound boat, jet drive whats your thoughts on how you would set this up to get max. speed and torgue.( river boat 5,000-6,500 rpm engine) I know its not a speed boat but tired of having the slowest 21' open bow on the river. Your thoughts are greatly appreciated.
    Renegade jet tunneljet's Avatar
    Shorewood Il
    Do a search, I remember a thread something like 700hp 502 recipe (spelling)?
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    A good set of heads and an aggressive cam will get you in the 7-800hp range all day.
    Senior Member shimp's Avatar
    Southeast Texas
    What would be a "good" set of heads? Like some DART heads or something? Just asking, my 454 (468) is in the shop right now being built......
    Yucaipa, Ca
    Brodix, Darrt, AFR.... maybe even some cheap Pro Comps?
    Widowmaker will probably chime in here. He is running a 502 bottom end with really great results.
    Redding, CA
    I don't have dyno results, but am happy with my set of Brodix 280cc rect. runners. (BB1)
    They are the smallest rect. runner heads that Brodix makes, I believe.
    119cc Chambers.
    Perfect for 500 inch motors at less than 5500 RPM?
    Here is the link:
    http://www.brodix.com/heads/bb1.html
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Quote Originally Posted by Cobra 02 View Post
    I doubt that you're looking for 700+ for your 21' open bow, here's an engine I helped a friend with many mooms ago. He purchased a 502" short block and added Brodix Heads and a small roller cam:
    Sleeper CP
    San Diego, CA
    Default recipe
    2007 GMPP Gen VI 502 bottom end
    AFR heads approx 9.2 to 1 compression
    chris straub solid roller camshaft morel solid lifters
    Boat 405.
