Bassett T valve question
Results 1 to 9 of 9
    gets 'em wet ultrajet's Avatar
    folsom, ca
    Default Bassett T valve question
    Had water coming out of the headers at idle yesterday, water pouring out of the weep holes, etc. Figured the spring broke, so I took it apart to replace it and turns out the spring and ball were OK. The T valve is pretty old and is pretty corroded on the inside. Question is can the T valve fail like this with extensive corrosion or crap in the valve or is something else likely going on here.
    Redding, CA
    Quote Originally Posted by ultrajet View Post
    My old one crapped out, it was very corroded.
    Make sure your' water dump from engine is open. If all the exit water is going through the T it will overload it?
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Done.... So.Bay*310*'s Avatar
    So.Cal
    I'm selling a brand new t-valve in the parts spam for $50 firm, buyers pay shipping. That is, if you need one. Let me know.
    folsom, ca
    Quote Originally Posted by So.Bay*310* View Post
    Thanks for the offer. Luckily, I had an extra one myself that a week ago I thought was good for nothin'.
    Newton Ks.
    If it is made of more than one kind of metal, it WILL corrode, but only when wet.
    Galvanic corrosion.
    H.L. Mencken
    The Earth
    Blog Entries
    24
    They are nothing more the check valves. If the seat the ball seats against is corroded the valve will leak.
    Rexie is prolly right(new one time), it's a little junkyard but you might be able to stretch the spring a little??
    folsom, ca
    Well guys, no surprise here, but changing out the T-valve solved the problem. Took it out today and plumbing is fine. Thanks for all of your posts guys.
    Jet boat service
    Sebastopol Cal.
    I sell the Bassett T valve only , because it is All stainless. The aluminum versions corrode much quicker and cause problems. The Bassett valve is more expensive, but worth it. Jim
