SS braided line for Hyd. Diverter ?
Results 1 to 14 of 19
    Senior Member oldbuck40's Avatar
    Default SS braided line for Hyd. Diverter ?
    Do you guy's that use SS braid for the diverter have any do's and dont's for going through the hull part of the installation? im looking for something that looks clean and neat for the Funjet!
    San Diego, CA
    use bulkhead fittings to go thru the hull
    Boat 405.
    http://www.rexmar.com/page129.html
    there's pass thrus on that page. hass bought a badass hyd line pass thru from rex awhile back for his stealth but i couldn't find it. its a nice anodized billet plate with the pass thrus on it, looks sweet.
    thats what im looking for! just couldnt get the words on the puter this morning guess i need more
    Quote Originally Posted by oldbuck40 View Post
    found em
    http://www.danamarineproducts.com/Pr...productid=1159
    woo, them cost a penny
    DAMN! you aint kidding! i think i will just use that kit Rex has and use blue stringer washers for those fittings to go through i had to do that on the bilge dumps also being the hole was cut for those crappy plastic fittings and the stainless dumps i have were too small!
    that'll look nice too! you trying to finish up the funjet 1st? need to get busy on a turbo mota for the gullwing
    Yea trying to get it done and outta the shop here at work so i can take it home!
    dont like a whole lot being done,,right now just waiting on a few things from Tom to arrive on the Brown truck so i can finish up the engine compartment! then its on to wiring,steering,shift control,and rub rail! Then its off to the water!
    Ladera Ranch
    $84 !
    WOW.
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    SS bulkhead fittings, SS lines from a Parker fittings store.
ID:	42604   Click image for larger version.
Name:	Boat for sale 020.jpg
    Loose, the Dogs of War!
    These bulkhead fittings terminate in a 45*.
ID:	42606   Click image for larger version.
ID:	42607   Click image for larger version.
ID:	42608   Click image for larger version.
Name:	Boat for sale 010.jpg
    Las Vegas, NV
    i just did a hydrolic setup today and used the plastic bulkhead fittings with the plastic lines. man, what useless piles of garbage those plastic bulkheads are.
    they arent long enough to go through the Transom adapter....and forget going through the transom itself if you have any wood backing on it. they are good for only going through 1/4" thick or less surfaces.
    and the plastic lines look like hell to boot.
    ill be spending the extra coin for the upgraded braided stainless lines. the plastic ones and a lot of sillycone will do for now.
    Redding, CA
    Quote Originally Posted by Brad @ SCJB View Post
    I don't know if they are all that bad.
    I ran the plastic ones out of the left side of the plate, one above the other (In front of the "B" in Berkeley). The plastic fittings worked great for me, after tapping the holes for them in the plate. (1/2" 20 tap)
    Although I also plan on upgrading, they are working great so far.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    This is the kit we make up , uses AN and AN bulhead style fittings ,can be standard plastic line or Braided stainless inside Tom
