water pressure regulator plumbing?
Results 1 to 12 of 12
    Senior Member crf311's Avatar
    Meraux, LA
    Default water pressure regulator plumbing?
    Here the deal. I'm adding a watts water pressure regulator to the cooling of my BBC jet boat. This is how I have it plumed. the water is coming off the pump to an open/close valve. then to the pressure regulator, to the front of the block, then out the t housing to the water jacketed headers. Is this correct? Do I need to install a water dump somewhere in the colling system? Thanks.
    Imo you should have 2 dumps, one to the injection lines(header) and 1 overboard.
    Senior Member oldbuck40's Avatar
    Yucaipa Ca
    X2........
    Redding, CA
    X3
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Quote Originally Posted by bajadad View Post
    X2........
    X3
    If he had water injected headers you would be correct. If you read his post again you will see he has water jacketed headers. These should not need an extra dump line unless, for some reason, the manufacturer recommends it. If his exhaust is just the common aluminum "logs"(sometimes mistakenly called "headers"), then again, no extra dump line. All water exits through the exhaust.
    CRF311, post a pic of what you are running. From the pics in your album, it looks like you have injected headers.
    Good catch oldsquirt. If I had seen jacketed, I wouldn't have posted I've never owned any(no clue).
    Meraux, LA
    Thanks for the reply's.
    Oldsquirt, the pics in my ablum show my old set up. I was running Bassett ot headers. I have switch to some Lighting water jacketed headers. I added the pressure regulator so I wouldn't need to worry about over pressure in the cooling system leading to water in the oil. Let me see if I have some new pictures of my set up. Thanks again
    Meraux, LA
    I'll take some pictures in the morning. Thanks
    Meraux, LA
    here are some pics of what I have.
ID:	42682   Click image for larger version.
ID:	42683   Click image for larger version.
    Meraux, LA
    TTT anyone
    [email protected]
    Ohio
    The way I see it is the headers have small volume for the water and could restrict flow out of the engine and need an extra dump. Also years ago when my dad was running in board he ran the in coming water to the exhaust manifold first to cool them and heat the water. It then went thru the engine and out the tail pipe just past the manifold to cool them.
    I would think your best bet would be to talk to Lighting.
    Tim
