speed coat ?
Results 1 to 6 of 6
speed coat ?
    old HB member. 4604me's Avatar
    oxnard ca.
    Default speed coat ?
    is it a paint or a graffite lubricant, or both, does it stick like paint. or do you have to keep reaplying it. how long does it last, i have seen pic of it on boat bottoms and wonderded if its worth it. thanks steve
    just a half turn before it breaks.
    Default Paint
    Quote Originally Posted by 4604me View Post
    It is a grafite based paint that you thin with acetone and roll it on. Is it worth it? I don't know for sure, but I can tell you to tie the boat to the trailer very well.............Ray
    LOUD BOATS SAVE LIVES
    Senior Member tahitijet's Avatar
    this is true. I put it on the bottom of a flattie i've been working on. After putting the coating on I had to strap the boat to the dolly because it would slide on the dolly just leaning agianst the boat.
    Yes it sticks like paint and yes it will wear out. HOw soon and how bad depends on many factors.
    Yucaipa Ca
    Is speed coat possible while still on the trailer, I was thinking suspending the rear of the boat from an engine hoist, and work on it that way. Please correct me if i'm outa line...
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Quote Originally Posted by bajadad View Post
    Yes it is
    Takes about a thousand coats doing it upside down. the can we got was as thin as water. It applies great going with gravity. takes a while going against gravity.
ID:	43419   Click image for larger version.
    Yucaipa Ca
    Thank for the heads up Infomaniac...
