Berkley jet repair question
Results 1 to 14 of 33
    "BOUGHT NOT BUILT" 2FORCEFULL's Avatar
    Default Berkley jet repair question
    Can I just remove the ten transom bolts, cut the silicone , slide the transom box back,
    un bolt the bowl bolts, put a new gasket and slide the transom box back on with out
    taking the rest apart
    Fallbrook Ca.
    yes
    Fallbrook, Ca.
    Basically , just like you say, disconnect your cables , reliveve the silicone around the bowl and the hull , pry of the transom adaptor off, clean up and reverse process , call if we can help Tom
    why do I have to un hook the cables? can't I side it back enough to put the gasket in
    Ladera Ranch
    You can do it like that, but it would be easier if you take the cables off.
    where is it leaking? bowl or transom adapter?
    #55
    the bowl gasket is leaking
    Ladera Ranch
    If the gasket hasn't pushed out you can try tightening the bolts. I'm not sure what the torque spec is on those bolts, but they require some leverage to prevent leaks. I weigh 200 lbs and I put every bit of my weight into the wrench when tightening.
    Senior Member Jetboat Jared's Avatar
    Apr 2009
    independence oregon
    Quote Originally Posted by 2FORCEFULL View Post
    i wish my transom looked that pritty lol i got over spray when i was painting the pump lol
    I try'd to tighten the bolts... no workie
    Long Beach
    Despite what you're being told, never reassemble (or assemble for that matter) the TA using silicone. If you use the rubber gasket, bowl ring and some white grease, it'll never leak and taking it apart the next time will be cake. The only time you need to use silicone, unless you're lazy, is if you have a set back.
    Nice looking boat.
    Quote Originally Posted by old rigger View Post
    Nice looking boat.
    whats the ta?
    whats the ta?
    The transom adapter.. The dealio that says berkley.
    Sacramento Ca.
    Nice looking boat.
    WHat kinda grease are we talkin??? Im about to throw the adapter on tomorrow and was gonna silicone.. But i do remember how much of a pain in the ass is was to get off because of the silicone. Id like to try this grease method lol.
