i need help
Results 1 to 12 of 12
i need help
    BOOMER SOONER 426hallet's Avatar
    sacramento,ca
    Default i need help
    so i bought a 76 cheetha that had a big block ford in it i want to put my big block chevy in. what steps do i need to do to make this happen thanks jerry...... and i have all the engine plates for the chevy
    Colfax, Ca
    Motor plates, headers and PTO
    Water in, water out, a BBC jet pan, exausts, and depending on what driveline the Ford has possibly a PTO and/or driveline Call if you need help Tom
    ps then be prepared to watch/listen to the Ford vs Chevy and Chevy vs Ford arguments
    sacramento,ca
    hey guys thanks but thats not what i ment.. what i ment was is there any thing i need to do speacial when putting it between the stingers. is ther a certian angle that im looking for, should i center the bolts in the stringer or are the holes in the stringer for the ford the same as the chevy
    Quote Originally Posted by 426hallet View Post
    Still not certain I understand but ... if your starting over with a different engine etc everythings going to change to some degree ,depending on mounts driveline and a multitude of other things . The engine "angle" and position for the Chevy is going to be the same as it was to the Ford Whether 3 pt or 4 point mounts there will still be holes to drill Tom
    sacramento,ca
    yeah i am starting over with a hole new engine.. i know i will have to drill some holes... so is the best way to do this , to put the engine betwwen the stringers hook up the drive line,, mark some holes ,, pull it back out and drill those holes.. it cant be that simple.. let me know thanks tom
    Redding, CA
    Sounds right to me. What else is there?
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    sacramento,ca
    i dont want to **** anything up . i know it sounds simple enuf but arent those the famous last words
    sacramento,ca
    hahahaha you cant say the f-word on here now thats funny
    sacramento,ca
    how bout it does that sound right
    Jerry Give me a number I'll call you after a bit ! tom
    sacramento,ca
    pm sent tom
