place diverter more roost
Results 1 to 14 of 21
    Apr 2009
    Default place diverter more roost
    anyone ever had any luck by machining the upper half on there diverter to get a few mor degrees of roost. looks like that it can be done easily. 12e with hyd diverter thanks
    Senior Member Ken F's Avatar
    it would be much easier to put in a wedge between your bowl & divirter.
    Ken
    The liberals are asking us to give Obama time. We agree and think 25 to life would be appropriate.
    Newton Ks.
    Yep, wedge it unless you are running the Place on a C/E/F bowl (non-split bowl).
    H.L. Mencken
    Newton Ks.
    And frankly, if you want a LOT of roost height, swap to a split bowl, so you CAN wedge it.
    H.L. Mencken
    Apr 2009
    ya thats the thing i have a 12je factory set back pump deal. i machined it out to were the sealing surface in the diverter was still in contact to the bowl so i wouldnt have any blow by and picked up 3.5 more degrees up with it, on another note is it possible to do a direct bowl swap to a split bowl if i dont already have a split bowl so i could do a wedge or droop??
    Newton Ks.
    Yes, I now run an Amer. Turbine split bowl. Orig an "F" pump with factory elec. diverter.
    My understanding is, AT and Dominator were begun by Berk employees (former). Berk was always the most numerous pump out there, and comonality has been a very good thing for the last 30+ years.
    H.L. Mencken
    Senior Member 4trax's Avatar
    Shawano, Wi.
    Quote Originally Posted by jakelake View Post
    Could you post a pic of what you did?
    I went in and got recircumsized again........I lost 10lbs. & was able to save the lives of 3 children in the burn center.........but it's not my fault they turned out to be dickheads.
    [email protected]
    Apr 2009
    ya i will when i get off work tonight it worked out bitchen
    here ya go newbies
ID:	43012   Click image for larger version.
    just be carefull not to take to much away , it'll allow the seal to blow out
    Southwest corner AR
    You also have to slick off a little on the cable brackets they touch together! WT
    WT
    WFL Crew!!!
    The Man cordog009's Avatar
    East Texas
    Yep, mine is adjusted back as far as it'll go without grinding on the arms. If they weren't chromed I'd have already fixed that too.
    1984 Youngblood TX-19 SOLD
    lol, right..... Devilman's Avatar
    South Texas
    here ya go newbies
    Nice watch....
    Shawano, Wi.
    I still have the factory electric "JET-O-VATOR". I thought that is what he had. I must have read it wrong sorry.
    [email protected]
