Does anybody make...
Results 1 to 9 of 9
    Default Does anybody make...
    ...a 90 degree thru-hull water dump fitting by chance? Need one that will accept 5/8" ID hose.
    Ladera Ranch
    Do you want the angle inside or outside of the boat?
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    Get AHOLD OF TOM, (JET BOAT PERFORMANCE) HE IS ON THE BOARDS HERE , HE CAN HOOK YOU UP! SHOP #1 805 466 4719,
    Tye,
    Inside.
    Basically, every thru-hull dump fitting I've seen is usually a straight one with a barbed hose fitting on the end. Problem with that is that the hose has to raise up between the motor and the transom to connect to the dump fitting.
    What I'm trying to do in an effort to neaten up the hose array in the bilge area is have the hose stay on the floor of the bilge until it gets to the transom, then curve up and follow the transom, then connect to the dump fitting.
    The Earth
    Blog Entries
    24
    We make one that has a -8 AN connection. You could put a 90º -8 push-lock (barbed) XRP hose end on it and attach a 1/2" hose.
    Thanks Rex. Out of curiosity, do those push lock barbs require a certain type of hose or will they work with any hose?
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    I think it takes a special hose but I may be worng. I know I tried them and they are still in a box. 2 of us pushing and couldn't get past the first barb. Heated the hose, added silicon grease and nothing.
    Wags
    The Earth
    Blog Entries
    24
    They are designed for push lock hose (the blue XRP stuff). You can use other hose obviously for a non pressure application. You can use a clamp (not overtightened) to be safe.
    When installing the correct hose you generally have to do it in a vice or very secure location on the end, use a little grease and push like hell. They go on, just not easy. Same reason they don't come off.
    Jet boat service
    Sebastopol Cal.
    Give me a call Jon. Jim
