Ford lost oil PSI
Results 1 to 14 of 33
Ford lost oil PSI
    Junior Member In Heat's Avatar
    Default Ford lost oil PSI
    So I have a 460 bbf that is basically stock besides a small cam and I need some help from you guys. When its cold i have around 50 psi and all is well. as soon as it warms up it drops to like 10 and the lifters start clickin. so what do you guys think? oil pump? Main bearings? Also since im guna be tearing this thing down a little what do you guys recomend to get some more hps out this thing without spending my life savings? I was thinkin bigger cam maybe....what size is good for a jet?
    Senior Member Ken F's Avatar
    Kinda sounds like mains. You didn't mention rpm but I'm assuming that you mean it drops to around 10 at idle?
    KEn
    The liberals are asking us to give Obama time. We agree and think 25 to life would be appropriate.
    From past 460 experience open it up before it self destructs. Most 460 run 60-70 lbs
    ya around idle its super low 10ish and at a like 3500 it hit maybe 25 max. i pulled the motor out tonight and am going to tear into it tomorrow so well see. Any ideas on what cam to run?
    Morgan Hill
    If the lifters start clacking before the rods start knocking, I would bet on a spun main or cam bearing.
    GT
    GT
    thanks thats what i was thinkin too but im not a super motor head so i wasnt sure, just a garage guy that knows a little about a lot. Here is a pic of my boat so this thread doesnt totaly suck to read
    Senior Member OUTLAW HALLETT's Avatar
    SHASTA LAKE CA.
    it doesnt look like anyone wants to answer you about the cam, i would suggest going to comp cams web site and downloading the dyno ,cam selector, it should give you a good suggestion on what to use and it will show you , what difference's each cam will make ,, good luck ,
    http://compcams.com/camquest/default.asp
    Redding, CA
    Quote Originally Posted by OUTLAW HALLETT View Post
    I've ran several of their "extreme marine" grinds in Chevy jets. Currently have the XM 296 HR (Hyd. roller) with 9.5:1 compression. But have ran the extreme 280 Hyd. flat with great results. That is with BBC, however.
    You will like the 280 range hydraulic cams for not a lot of cash. Just don't get Too wild depending on your compression ratio.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Monroe, WA
    We had a Ford with low oil pressure once. I took it apart and noticed an oil pump bolt loose and it had spit out the mounting gasket.
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    San Francisco Bay Area
    Cool
    Quote Originally Posted by In Heat View Post
    The diminishing oil pressure could be a number of things, but it sounds typical of worn bearings/loose bearing clearances.
    A good budget cam that you can run for cheap is the Summit Racing house brand camshaft SUM-3501. It's a good camshaft for the stock marine 460 because it is mostly duration (easy on the OEM valve springs). If your current camshaft is bigger than the one I recommended, then you will need more valve train upgrades (pushrods, valve springs, valves, etc), and the engine's performance would be vastly improved from also porting the heads, particularly the exhaust ports in your case.
    Run a Holley 850 cfm Double Pumper carburetor.
    LO
    High Flow Dynamics
    Cool
    GT
    It's possible but the lifters are fed oil in these engines before the mains see it, and so a spun main does not cut off oil supply to the lifters.
    LO
    High Flow Dynamics
    Quote Originally Posted by LakesOnly View Post
    A good budget cam that you can run for cheap is the Summit Racing house brand camshaft SUM-3501. It's a good camshaft for the stock marine 460 because it is mostly duration (easy on the OEM valve springs). If your current camshaft is bigger than the one I recommended, then you will need more valve train upgrades and the engine's performance would be vastly improved from also porting the heads, particularly the exhaust ports in your case.
    LO
    i've ran that 3501 summit cam before, worked great in my taylor sj in frt of a a cut
    Cool
    IF you want to run a camshaft this big in your 460 you will have to do a lot of valve train upgrades and/or be willing to spend a lot more money than it sounds like you care to.
    In Heat, perhaps you should tell us how much hp you want and what your budget is...
    LO
    High Flow Dynamics
    Redding, CA
    In Heat, perhaps you should tell us how much hp you watn and what your budget is...
    LO
    True, the Hyd. flat will require springs, retainers. Lifters are a given any way, I believe.
    Does that motor have pedestals, or studs??
    Tommy
