High Low Intake Pressure
Results 1 to 10 of 10
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Default High Low Intake Pressure
    Saw a pic recently of someone's setup.
    Can someone post it please. I can improvise but would really like to see one that works.
    Assuming your talking about the tap locations....
    New Port Richey, FL
    Yes thanks.
    That location is under the transom plate It's outside the boat but under the plate.
    Yes thanks.
    you can move back a tad to clear if ya got the room
    New Port Richey, FL
    Yea the fwd third of the clean out hand hold is even with the transom.
    We just have to pull the transom cover to drill and tap. I thought about doing it before we reassembled, but if I had there would have only been one tapped port. And in the wrong spot.
    So did you find out if we can try the impeller before we buy it? Or how much he wants for it?
    250 for the impellor, he wants to just sell it outright to pay me back for the aeromotive pump i bought him this mornin if you're currently runnin a b-cut, this mpd impellor will feel and bite like a small a-cut or ab. he turned it 7800 with about 1400hp(blown 540 with a 250hp shot)
    Southwest corner AR
    I was also told by someone in the biz. that the fittings need to have a small keen hole! For good accurate readings. Fill the fittings with JB weld or bondo and drill a 1/64" or a 1/32" hole through the filler! This is because the fitting might not be stright with the water flow through the housing and may act as an evac causing it to suck on the fitting port! Thus not accurate reading! FWIW! WT
    WT
    WFL Crew!!!
    Senior Member hotbo's Avatar
    lake Ouachita AR
    when i tapped mine i used 1/8npt fittings, with well water pressure gauges and clear line,run them over the back of the boat and set them in the seat with me.lol!!!run down the lake and recorded pressures at different rpms and speeds.found my problems and then resolved them.worked great.travis
    obtw thats hillbilly style maybe to crud for others
    Clovis, Cali
    It might be hillbilly style and crude, but thats what I'm doing too.
    "Knowledge is power" the effective way to add ,subtract or change "hardware and setups" is with feed back
