Finally. . . . 18' Rogers finished!!!
Results 1 to 12 of 12
    1 boat's never enough Bigtorq's Avatar
    The OC
    Default Finally. . . . 18' Rogers finished!!!
    Sorry for the excitement but I finally finished my 75 Rogers project. I replaced a worn out 455 with a BBC and took it out to Smellsomore last weekend. Other than completely destroying a Fram oil filter (never do that again), everything worked out great. All stainless hard line water and fuel lines with a set of custom water valves. Modified 1/2" AN T fittings with cap bolts to meter the exit water flow.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Cool
    Santa Clarita
    cool...got any smaller pictures???
    Nothing to be sorry about.
    Congrats on the project
    S CP
    Just use a mag glass
    S CP
    The OC
    I thought they were clickable . My bad.
    Senior Member nick's Avatar
    Fullerton & Water Wheel Resort
    looking good, nice touch with the all hardlines, definatley a differnt look.
    Canyon Country, CA
    Quote Originally Posted by nick View Post
    reminds me of the bassett ads. looks good
    p.s. hows that throttle cable workin out for ya?
    The OC
    Quote Originally Posted by Robert Jonsson View Post
    The picture shown above was one that was taken before I finished it. Here's the pic after getting back from the lake with the throttle cable where it should be. Bye the way, the scoop is facing backwards because we were trying different things and turning that way increased rpm by 300. Found out later that I had an old fuel filter tucked under the rear panel that's probably been there 20+years and with 1/4" nipples on it. I replaced it and now have all 3/8" fuel line so should be able to twist it back.
    Southwest corner AR
    Looks great! What coating do you have on your headers and who did it? WT
    WT
    WFL Crew!!!
    Yucaipa, California
    i agree! Definitely looks bitchin!
    1992 Eliminator Daytona 21'
    The OC
    Ceramic coated Rewarder headers. these are actually V-drive headers (so I was told) and that's how I got them so don't know who did it. Wasn't sure how they were going to look since I was putting them in a jet but came out nice.
