Need help choosing a cam for my 460...
Results 1 to 14 of 15
    Default Need help choosing a cam for my 460...
    I am doing an intake swap on my 460 and figured now would be a good time to do a cam swap. I want a cam to have a lopey idle and have good vacuum....What does everyone recommend? I have an edelbrock performer rpm intake and edelbrock carb on it right now.Also,its a 20' Southwind with a berkley jet
    ive come across a lunati cam...here are the specs
    idle-5000- duration at .50" 207/213 Lift int. .503/.535
    or a crane cam
    1500-4500 duration at.50" 204/216 lift int. .487/.518
    All and any info will be greatly appreciated,
    Jon
    i'd shoot for alil more duration to help the heads breathe, exhaust ports are horrible on those heads you're not gonna get away with much more lift, but you should be able to pull off 530, and make sure you upgrade springs
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    if your using logs becarfull
    Anaheim/BHC- the Shack
    I run a Comp 280H with .530 lift, and 230 deg @.050. No problems with logs and reversion, but I'm not comfortable with more duration than that. You may need to machine the spring seats for this lift.
    Thanks for all the info! What does everyone recommend if I am running logs?Also should I just leave it stock?Its a 70 block if that matters
    Tri-Cities, TN
    Quote Originally Posted by 220Motorsports.com View Post
    You can get away with a little more duration but OEM Ford heads like a alot of split. I would look for something like 215 on the intake and 230 on the exhaust at .050". Make it around 540 lift on intake and 500 on exhaust.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    San Francisco Bay Area
    Cool
    or a crane cam
    Jon
    Jon,
    Don't know enough about your engine combo, but if the longblok is essentially stock then the Summit Cam p/n SUM-3501 will work for you. 0.503"/0.503" - 218*/228*@0.050 - 114 LSA. Close to what Straub recommended and with the "good vacuum" you desire.
    Next power ugrade: ditch the Edelbrock carb for a Holley 850 cfm Double-Pumper.
    LO
    High Flow Dynamics
    Quote Originally Posted by LakesOnly View Post
    Jon,
    LO
    Thanks for all the USEFUL INFO!!!!!! This is a new "game" for me...With that cam,will it give me a lopey idle?Also,can I use the stock valvetrain or would I need to upgrade?
    460
    460 is offline
    ATTA BOY 460's Avatar
    Quote Originally Posted by slowride View Post
    Same cam i have and its been a great cam. Nice lope to it too
    76mph at 5k with this one.
    Did you upgrade your valvetrain or need anything else besides the cam to finish the swap?
    460
    460 is offline
    I got a complete cam kit when i built this motor 5 years ago. I would get a cam kit and go from there. I only have roller tip rockers on mine.
    does anyone have videos of their cams in action?
    did everyone upgrade their valvetrain or keep the stock push rods and lifters
    Get the cam kit, you will be money ahead, and yes you need to have the heads (spring height and pressure) set up for the cam.
