Jetovator
Results 1 to 10 of 10
Jetovator
    Default Jetovator
    Was wondering if i can grind stop on jetovator to gain more adjustment.
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    sure just don't go to far!
    Does anyone know how much i should grind on it?
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    intill the o-ring appears on the nozzle or you run out of throw
    lol, right..... Devilman's Avatar
    South Texas
    I'm pretty sure it was Squirtcha? that had some pretty good pics of a jet-o-vator that he ground on to get some more up-travel...
    Would like to see the pictures. I have no problem grinding on it but, if someone else has already taken the guess work out of it then it would make it faster for me.
    Sep 2008
    i also have a jetovator and i have ground down the stops. you will have to take both sides and top stops down. i only took mu down a little to see what happens. now with my handle all the way down the nossle is level. so i got more up and less down
    Jun 2011
    Yuma, AZ
    Question jetovator
    Hey cjaj70.....did u ever get to grinding ur jetovator and if so how much did u grind off and did it give u any good results....I'm new to this ....thanks
    Kingman/Golden Vly, Az
    Quote Originally Posted by Devilman View Post
    yup ...he has pretty good pics of what & where to grind!...PM him...i'm sure he will post up or send them to you...just sayin' FastRat
    Senior Member GA Jet's Avatar
    May 2010
    I ground mine almost flat! Just took a bit off at a time to make sure I didnt damage anything
