rpm pill
Results 1 to 13 of 13
rpm pill
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default rpm pill
    Anybody have a rpm pill for the MSD 6AL around 6500 rpm they want to part with?
    Default Pill?
    Wouldn't that be a "chip".........Pills usually refer to fuel systems.......Ray
    LOUD BOATS SAVE LIVES
    Bullhead City, AZ
    I will trade you one for wheel lug lock key !
    Actually what is your projected max rpm ? I ran a 6K being I was expecting a max of 5700, I took it out and put in a 7K and it woke the thing up big time. Quickness and top end.
    Ray is 100% right on this, they are chips !
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    San Clemente, Ca
    Quote Originally Posted by Squirtin Thunder View Post
    Hmm, could have sworn MSD called them pills, looking at there site they call them modules. Oh well...
    You lookin for the wheel lock key for that trailer i sold Ray? I have it if you need it or if you want to get them off, just hammer a socket on them. If you look close i did that once to one of them, forgot the key PM me your addy and i'll send it to you.
    My target rpm is 5800 off the juice, i think a 6K module is too low and a 7K module is too high... thats all i have.
    Bullhead City, AZ
    I was just jokin on the lock key, a day or two after Ray showed up with the trailer we were moving it to open storage. I brutilized the locks with a socket. I did not havce the 6500 eather but the 7K was jst fine for the great balance job the lil 429 got down in Avondale at Tuf-Enuf. Timm did a fantastic job. My next BBF will have a Mag and no rev limiter and yes it will be done at Tuf-Enuf again. I really think balance and clearance is the key to revs. The PS89 turns right around 7200rpms, it has a rev kit on the push rods. They had one engine failure in about 22 or so heats, no bad in my book. My CJ72 Sanger likes to fly and was hitting the 7K chip about 10 times a heat.
    BTW - The shaft checked out perfect and is in a real tight pump as of today, .009" side clearance and .025" thrust. Thank you !
    Jim & Amanda Rich
    CJ 72 & 53c
    Charlotte, NC.
    I got a 6 you could have but sounds like you already got a six. Just order new ones from jegs. An entire set is 27 bucks.
    http://www.jegs.com/p/MSD/MSD-RPM-Mo...46842/10002/-1
    Done.... So.Bay*310*'s Avatar
    So.Cal
    Shaun-I have what you need. I bought the whole module kit last season. If you'll be at the race this sunday, i'll deliver it to you at the beer garden.
    Senior Member Futs's Avatar
    Orange CA, Big River
    You should run a minimum of 400 rpm above what you think or know the max rpm is. I was running a 6600 chip and it was hitting the limiter and I was only spinning 6300. Changed out the chip to 7k and it runs so much better on the big end!!!
    Just my .02
    Charlotte, NC.
    Just my .02
    thats good info.. I need to move mine up.. thanks!!
    San Clemente, Ca
    Quote Originally Posted by So.Bay*310* View Post
    I'll be out there sunday
    San Clemente, Ca
    Just my .02
    Kinda what i was thinking. If i'm spinning 5800 i dont want a 6K chip because it's too close to 5800, but i also dont want a 7000 chip because i think tagging the motor at 7K and then loading it back up enough to drop it down to 5800 is alot and probably hard on parts.
    I tend to tag the shit out of my rev limiter, i run through alot of chop.
    i would put a 6600 or so in it. They tend to come in way before you even hit the chip marking rpm.
    San Clemente, Ca
    Hmm, maybe i'll just buy the 6000 kit with 200 rpm incrments so i can play and see where i need it.
