455
Results 1 to 8 of 8
    Default 455
    what is a good gap for plugs for this motor
    Default More info
    Quote Originally Posted by kona15 View Post
    What distributor are you using? A standard type, (point) ignition is .035.....An HEI type stocker would be .045-.060, depending on the coil output. A Magneto type ignition w/o an external transformer, .018-.020. A mag w/ext transformer, refer to unit instructions as there are several variables........If it is an aftermarket distributor/system you can always go to their web site for detailed instruction sheets. Hope this helped you, Ray
    LOUD BOATS SAVE LIVES
    Damn Ray your like a walking "Olds repair manual" Good job !
    Default re
    wow! thanks. it is just the standard points and condensor type dist
    Yucaipa, California
    i take them out of the boxes and screw them in...olds is a party motor.
    1992 Eliminator Daytona 21'
    Default re
    ha ha thats funny
    Default Easy ones
    Well I'm old and slow, so I have to jump on the easy ones once in a while. I actually sold auto parts when we sold more points and condensers than HEI caps and rotors. We also stocked Y block Ford valley gaskets...........Ray
    PS Also SDN1A starter drives for every GM starter in the world!!!!
    Member pushingvws's Avatar
    auburn, ca
    Quote Originally Posted by Tahiti Boss21 View Post
    Amen, cept I do that with any motor. Hasn't failed me yet.
