What's the best starter for a big block 460 ford ?
Results 1 to 7 of 7
    Senior Member chrisbsanger's Avatar
    Grass Valley
    Default What's the best starter for a big block 460 ford ?
    What are you guys using ?
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    I'm using the stock starter that came with the motor. Works great for me.
    Wags
    Santa Clarita
    Im using one of these on my 501....10.6:1 and starts it no problem every time. #IMI 106T
    http://www.rexmar.com/page306.html
    San Francisco Bay Area
    Cool
    Quote Originally Posted by chrisbsanger View Post
    I have known the production OEM 1993-up F250 mini-starters to fire 665 cubic inch all-alumunum Fords without breaking a sweat.
    LO
    High Flow Dynamics
    Glendale Arizona
    Autozone $35 special with lifetime warranty. Still waiting to use that warranty after 7 years.'
    A buddy of mine bought two of them for his Ford. He figured for $35 it had to be a piece of crap and thought it was a good idea to have a spare. It's still in the box 10 years later (he doesn't use his boat much any more though).
    Senior Member Camoman's Avatar
    AREA 51
    Quote Originally Posted by LakesOnly View Post
    LO
    Yes the 3226-s is the one to use
    There's doing it easy,or there's doing it better
    I've had stock starters last over 5 yrs. The current one on the 12:1 565" is over 10 yrs old maybe 12yrs has been used for at least 8. If you're killing starters put a large car washing sponge between the oil pan and the starter at the bell housing. Before I learned that trick we would loose a starters every 3 trips. It's a Pep Boys.... I remember...." is your truck a two wheel drive or 4 wheel drive" Hey just get me the phucking starter would you !!!!!
    LO
    Thanks for the heads up, I think one of those will work better with my new kickout oil pan.
    S CP
