steering kit
Results 1 to 9 of 9
steering kit
    Senior Member bc18's Avatar
    Default steering kit
    i have an old rack and pinion type steering system in my eliminator bubble deck. the cable is getting stiff so i want to just go with the steering box kit. i went to rex marine today and told the guy about the steering box kit i wanna convert to and he said those are weak and not to use them. Is this true or is he sniffin some crack?
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    I think I would call Tom at Jetboat Performance and talk to him or Josh. I would go back to new rack and pinion. It works great on my boat and will be installed on my new little hotrod. Simple to hook up and no maintainence.
    Wags
    Quote Originally Posted by bc18 View Post
    What is this so-called "steering box kit"? What manufacturer? You do know that in all likelyhood you can simply replace your cable assembly.
    Sacramento, CA, USA
    That's what I would do too. And grease the rack gear.
    Wags
    "BOUGHT NOT BUILT" 2FORCEFULL's Avatar
    where can you get just the morse cable??
    Sacramento, CA, USA
    Call Tom at Jetboat Performance, 805-466-4719. He'll give you the best deal.
    Wags
    El Cajon, CA.
    X2, last time I talked to him about cables he had pallets of them waiting for customers.
    The Earth
    Blog Entries
    24
    Quote Originally Posted by 2FORCEFULL View Post
    The old Command 200 rack replacement cables (Teleflex) are still available. Morse was purchased by Teleflex several years ago. Just not the old Morse rotaries aren't available. The Command 200 is a good helm if not worn out or damaged in some way.
    The new Teleflex rack in the box complete kits are only $149 also.
    Thanks Greg !
