double bolting the droop and some math
Results 1 to 14 of 36
    Senior Member miketeast's Avatar
    maryland
    Default double bolting the droop and some math
    i have been having a discussion with someone about double bolting the droop...it occured to me to do some simple math...here is what i come up with:
    7 inches ~=~ diameter at the droop/bowl interface
    38 square inches ~=~ area of the droop/bowl interface
    ~300 pounds per square inch ~=~ bowl pressure (nice healthy big block like an unnamed sombody intend to run (an A impeller at 5900rpm)
    ~11400 pounds trying to separate the droop from the bowl
    8 bolts puts this at ~1400 pounds on each bolt
    each bolt is a 5/16" bolt...about 1/4 inch diameter of actual metal that the force is bearing upon...or ~ .05 (1/20) of a square inch.
    ~28000 psi is the force on each fastner by my dogfish90 calculation.
    this is quite near ~70% the yield strength of some stainless steels that are commonly (the unnamed sombody) and many others use as studs in this application, but only 1/5 the ultimate strength.
    Because i dont know I have not included the stress that the nut that holds the droop onto the bowl has on the stud...it has already preloaded the fastner to some extent, and in most cases the fastner is at an angle increasing the local stress further.
    Because i cant quantify it I have not included the shock forces that unloading and reloading the pump has on these fasteners...it is going to happen...the waters and the way we run...it is going to happen.
    i may be a little off on the bowl pressure, i guessed. I dont suppose wrong enough to change the story.
    i have not included the fact that stainless (especially near aluminum and salt water) will do some unexpected corrosion stuff on you.
    am i wrong that the bowl needs to be double bolted?
    where have i gone wrong with the math?
    does the reaction of the water leaving the nozzle offset these calculations and if it does, does that make the unloading/loading even that more hazardous?
    i dont think double bolting can hurt but at what point is double bolting necessary?
    Can i use this as a cheet
    EDIT: i fix the 5/8 5/16 thing
    Team FTL
    Horsepower Homo
    Centistoke Fag
    Glendale Arizona
    Well Mike...........
    I think that with all the time it took to calculate the forces at work, the might be, and what if, etc. then post it up here, you could've already double bolted it.
    After all what's it take? A drill press, a tap, some stainless allthread, nuts, washers and some time.
    I'd think that if there's even a question it maybe should have double bolts then have at it.
    How's your weather been? Getting out much?
    Morgan Hill
    I was always told the biggest reason for double drilling the droop is for lateral or shear strength, it does somewhat weaken the flange of the droop, so that needs to be taken into consideration.
    I would think double drilling the bowl would be more important (my pump and bowl are both double drilled).
    BTW, never seen a droop bolted on with 5/8" fasteners, only 5/16"...
    GT
    GT
    Yea.....exactly.
    Doesn't hurt anything.
    maryland
    mine is double bolted...but i only run 580hp max. and it was done with someone with a drill and a beer..yes it works but it aint no machinist pride.
    been really rainy...but that is not the real reason i havent been out...only person who can keep up is still putting it together...maybe this weekend (was supposed to be last weekend but it blew up on the lauch pad)
    GT
    yeah...Dogfish Head 90 had me there....5/16...but still .250 available meat for the stud.
    the calc on the bowl/intake come out WAY good, if these simple calculations can be trusted.
    I just wondered about the calculation. One can calculate till hell freeze over and bust and it dont reflect reality. On the other hand calculation can reveal something that reality and 'common sense' keeps hidden, to a wonderfull advantage.
    Team FTL
    Horsepower Homo
    Centistoke Fag
    Colfax, Ca
    Nice to see you over here Mike. Sounds like you have too much time on your hands!!!
    Call Jack @ MPD, he told me that mine needed double drilled at the bearing flange, bowl and droop.
    I can't remember what HP he recommended it at.
    maybe CS can tell us
    #55
    Large Member edog's Avatar
    Riverside, Ca
    I am reading all this and wonder if the material that the bolt threads into is a strong as the bolt itself. Maybe I need to read it again to fully understand.
    Quote Originally Posted by edog View Post
    It definitely is not and are very suseptable to corrosion.
    Brian
    spokane, WA
    Everything is double drilled on mine. Just go for it so you do not have to worry about it, it wont hurt anything.
    Travis
Name:	my new boat 9.jpg
    Quote Originally Posted by TwinTurbo540 View Post
    Travis
    Agreed, don't be scared.
    Morgan Hill
    Even my bearing thrust plate is double drilled billet
    GT
    GT
    Thrust Whisperer Doc Nozzle's Avatar
    Feb 2009
    Your math is correct. Your thinking about cyclic loading and corrosion is also very correct. The weak point may not be the bolt material but rather the aluminum in the bowl and inlet flanges. As you probably know, the shear, yield and ultimate strength of the alum alloy is far below that of the stainless (or any other) fasteners. The web of the flange on the intake may or may not be in shear depending on how you consider the interplay between thrust force and bowl pressure force. But the studs coming out of the bowl are definitely putting the alum parent material in shear.
    And then there's aluminum and the fatigue limit thingy. Depending on the make and vintage of your hardware, you could own some castings that are getting to be 30-40 years old and have had who knows how many cycles of loading?
    Thanks for putting the word "math" in a post on this forum!
    maryland
    Quote Originally Posted by Doc Nozzle View Post
    here is a good place to work the math such that the fastner fails before the thread
    http://www.engineersedge.com/thread_...engagement.htm
    it does not take into consideration the things you mentioned like distortion or weakening of the threads that happens by taking them in and out over the years....by the calculation it looks like the female threads are the week point for most...you got to have over an inch of engagement on a 5/16 bolt to even come close
    Yes, unseen is the actual conditon of the aluminum way up in the bowl. Also sometimes unseen are the things that happen to stainless, especially in salt water. Sometimes the failure appears like a stress rizer (like a rocker stud does)...other times the failure is associated with a black corrosion that has worked its way into the stainless. I have seen the liberal use of antisieze promote overtightning and cause the threads to pull too...i been using pipe dope as an alternative to antizieze too...sometimes both.
    by the way, the jet handbook thingy you found is great... explains mathamaticly how massflow in the intake (as referenced from the source water) can be subtracted from masflow in the nozzle...
    Team FTL
    Horsepower Homo
    Centistoke Fag
