rub rail
Results 1 to 9 of 9
rub rail
    Default rub rail
    mine is shot! its pop rivitted on. whats the best way to take off the old and put on new? can i use screws or is there a better way? thanks
    The Earth
    Blog Entries
    24
    Quote Originally Posted by kona15 View Post
    Drill the rivets out and screw the replacement on after sealing the old holes. Don't try and match holes, it never works out. We have complete selection of rub rail if you need.
    Default rub rail
    what type of screws, and how far apart. and what would i use to fill old holes
    The Earth
    Blog Entries
    24
    Most the rails are pre-drilled at varying intervals depending on the product. Some of the plastic stuff is not drilled so you drill yourself. I prefer filling old holes with sea goin putty, some guys will fill with silicone which is ok too. If you use sea goin, drill out any old silicone used on the old screws so you get a clean bond to the fiberglass.
    Screws depend on rail type. The type with the rubber insert should use a flat head screw. Non insert type generally uses an oval head as they look nicer and more finished. Stainless is preferred obviously so they won't rust and sheet metal screws are what you want because the threads run all the way to the head, wood screws have a unthreaded shank which is no good for this application. Size of screw again depends on the particular style of rail being used. I wish I had all this on the website so you could see but I don't yet. If you measure your old rail we likely have the direct replacement for it. A digital pic end shot and measurements helps too in id'ing what you have. Just give Brian a call here at the shop if you need info or help. 909-592-1000
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Where do you find the rub rails on your web site?
    Las Vegas, NV
    they aren't on their site yet as he just aquired them.
    Sacramento, CA, USA
    Thanks Brad. Not that I need them but others seem to like them.
    Charlotte, NC.
    Yes. i need to replace mine. the insert keeps coming out.. You know how bad it looks when your rubber insert keeps coming out?
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    I'm sure it is frustrating for the little lady as well.
    ENZYTE perhaps?
