yj energizer kit
Results 1 to 14 of 21
yj energizer kit
    gilbert, az
    Default yj energizer kit
    new to jet boats and just bought one. took it out for the first time yesterday and very dissapointed with my purchase. guy told me bbf had 550 hp and went 70+ with yj pump. well went about 46-47. would a energizer kit help me out here? if so how much would i be looking to spend on putting one in? would i be able to do it myself? thanks.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Quote Originally Posted by blaine View Post
    first tell us about your boat.congrats on the buy.
    this is usually the case 70plus mph,theres alot of them out there that are like yours.
    give all specs on the hull and engine build plus any info on the pump you can and i bet there will be plenty of help.travis
    gilbert, az
    it is a 76 omega bubble, has 5 hours on a bbf with forged crank, rods, ported cobrajet heads and port matched high rise intake, edlebrock 800cfm carb, forged alum dished pistons, msn ignition, duel valve springs, flat tappit cam, hardine water log manifolds, has a yj jacuzzi with nothing on it. i had tried to call the guy i bought it from to see if i was doing anything wrong but he would not answer or return calls. it was running on pretty smooth water at about 5300 rpm. this seems slow to me and the guy i got it from told me it would do 70+ with just him in it and mid 60's with a couple people in it.
    Yucaipa, California
    Tell that guy you bought it from that i got him covered with a 21' jet boat and a bone stock 455 olds with 30 years on it and the pump. That sucks! these guys in here should get you squared away!
    1992 Eliminator Daytona 21'
    lol, right..... Devilman's Avatar
    South Texas
    Sorry, but I doubt it was ever doing 70+ unless he was talking about when he was towing it to the lake. That said, a friend of mine has that same combo: Omega bubble, Ford, with a Jacuzzi YJ pump. When he got it, he ran it few times, think he GPSd it around 50-52 mph, something like that.... He went with an Energizer kit from JetBoat Performance & was really happy with it. Between that & a 521 stroker, he definitely got some more mph out of it. Not sure what speed he ever came up with though. 55 maybe? J/K I really don't know, lol... . He's not on here much, you may try PMing him though if you want some more details. PRO53 is his username, he'll be able to answer some of your questions. I'll see if I can't get him in here for ya...
    Senior Member Hustler's Avatar
    Tujunga,ca
    If I had it to do all over again I would pull the pump, have the glass work done and set a berk in it. For the money I spent on the energizer kit, place diverter and droop I could of found a used berk and had the thing set up right with a ride plate and shoe. It did make HUGE differance in the boats performance, the hole was was way better, the added place diverter helped with the ride and trying to free the boat up. But like I said if I was to do it all over again I would have gone another route.
    Senior Member 77charger's Avatar
    My old jet had the golden eagle we went with the energizer kit back in 89 or 90 right off the bat it was a big improvement.
    Over the years i learned the pump is where its at.I later had MPD rebuild,rework the impeller,and do some bowl work,I added a diverter too this was the best investment i made for that boat.speed went up rpm went down fuel milage went up.
    gilbert, az
    i found this pump on craigslist in my area
    Berkley 12JG Jet Drive with a AA impleller, droop snoot, hydraulic diverter, speed grate, only 10hrs on the pump
    he wants $1800 for it. is this a good deal? and any idea how much would it cost to get someone to install it? thanks for the help
    The YJ and G/Eagle Energizer by American Turbine, is (and has been a huge success bang fo b) Josh and I have built and installed countless units over the years and always with good /positive results . Generally it will be a huge improvement in the performance that stock YJ offering can offer ,increased efficiancy and overalll performance gains (not to mention the ability to use Berk style Bolt ons, place diverter ) I can honestly say I,ve never had a customer regret the "upgrade" (maybe the credit card statment ) Tom
    gilbert, az
    what kind of mph could i expect to gain with a energizer kit installed?
    From my experience at least a few but motor rpms will be reduced as well = more effecient.Like mentioned by above poster added bolt ons to further improve.
    Wish i had a pic of mine but it basically looks like the one posted by jetboat performance.Mine was the golden eagle too.
    Honestly 7 to 10 on average reported , like the "Charger" said the "bolt ons" after the swap availbale help as well Tom
    Tujunga,ca
    It will cost you that much just for the energizer kit, then you have the install of it plus the diverter
    gilbert, az
    how much would i be looking at to install the berkley?
