What's with Jet Boat speed????
Results 1 to 11 of 11
    Member bparsel's Avatar
    Default What's with Jet Boat speed????
    Alright, after reading the "YJ energizer" post question it has gotten me to thinking. I'm interested in a real discussion and explanation of why there is such variation in Jet boats? With a BBF and 550hp he is only running 47mph? That seems crazy to me.
    I realize the obvious regarding HP and Pump = Speed output
    But does more of a v-hull etc really impact speed that much? The numbers on a lot of Jet boats are just all over the place
    Douglas, MA
    Quote Originally Posted by bparsel View Post
    I saw this guy the other day...he was on his way to the dock...
    Senior Member River Dad's Avatar
    Riverside, CA
    bottom design (amount of lift = less boat in the water = less drag = more speed) and overall weight of the boat. Exaust type can also play a big factor as logs will kill that HP rating and the boat will see much less power at the pump. Just my .02
    Riverside, CA
    Also, the bottom on an older boat could be very suspect as far as hook which will kill speed real quick. After lookin at the other post, that does seem pretty far off from where you would think it should run...
    ptz
    ptz is offline
    so ca
    Unhappy
    too much cam....
    loud is not fast.
    pumps are out dated concrete pumps..
    to large dia of impeller....wrong pitch....to large intake....to small nozzle...wrong taper angles...etc.
    basically a pos design.
    HAHAHAHA!!! That is awesome!
    The main reason I ask is my boat is a deeper V, running about 525 horse, with all new pump components (stainless), a speed loader, a torker cam, a 1"lift adapter plate, a new Q-Jet and some other engine mods, and no logs and I pulled 68 on GPS sunday night.
    Santa Clarita
    My V-Bottom with 648 HP ran 92mph on GPS. It's all in the Setup..pump, bottom etc.
    Denton, TX
    Show off!
    Quote Originally Posted by ptz View Post
    pumps are out dated concrete pumps...
    Schwing, Putzmiester, or Thompson?
    Cas
    Cas is offline
    Angry American Cas's Avatar
    It might be 550 hp but where is it making it's power and what do the hp and tq curves look like?
    He could have 550 peak hp at 7000 rpm with only 250hp at 4000 which isn't any good for an all around use lake jet boat. If that 550 is at 5000 with 400 at 4000, it'll go pretty darn good providing the impeller is matched.
    There have been many people over the years that built an engine with the power curves in the wrong place that have been very unhappy.
    550 running 47, yea, something isn't right. What kind of rpms?
    Cas
    Cas is offline
    concrete pumps? how about irrigation ditch pumps.
