dual points Mallory distributor conversion to electronic
Results 1 to 11 of 11
    Alamogordo NM
    Default dual points Mallory distributor conversion to electronic
    Has anyone ever converted a mallory dual points distributor to electronic firing? I want to get away from screwing with points all the time. I see that Mallory sells a conversion kit, but I dont know if it requires vacum advance or not. Seems to me it would work, but I just dont know for sure. If it helps anyone answer the question I have mallory part number 2563401 for my distributor. Thanks.
    Alamogordo NM
    forgot to subscribe, had to post again.
    Yes, I've done the conversion on the mallory in my BBF. If memory serves me correctly the kit can be installed without even removing/retiming the distributor. It has made a world of difference and saved a few bucks.
    Short story:I was out on the lake one day and the boat wouldn't start. I could not figure what in the world was going on. Turns out a fried the ignition module. Summit racing was only a few minutes away so I went and picked up just the ignition module and it has been fine since(probably just due to my poor wiring/battery that was in my boat)
    Senior Member scottietwohoty's Avatar
    La Mirada, CA
    Default mallory
    I changer over my points dist. to eltronic and have never looked back!!!
    MONEY WELL SPENT!!!
    by the way it was also on a BBF.
    Alamogordo NM
    Default Just what I wanted to hear!
    Thanks Guys, I am going to do it, just wanted to make sure it was more reliable than points. I am running the red headed stepchild of Big Block motors though (455 Olds). We had to screw with the dist for an hour last weekend cuz we didn't tighten the set screw enough on one of the points. I hate being one of those stereotype "run it for an hour, work on it for two" Jet boaters.
    Tacoma Wa
    I hear the conversion burns out easy if you leave the ignition on? For some reason I am just stuck with my points ignition, something about their simplicity that keeps me warm at night and the boat miss-firing by day. heh.
    Senior Member Ken F's Avatar
    Yes, it is a good mod, but as stated previously, I would carry a spare in your toolkit!
    Ken
    Member neverenuf's Avatar
    North Texas
    Mallory has a power filter that installs inline to the module. protects against voltage spikes. Part# 650-29351
    Senior Member BigBoyToys's Avatar
    Spokane, WA
    Quote Originally Posted by 74glencoe View Post
    I just purchased an HEI off of ebay for $40 BRAND NEW AND REPLACED MY POINTS SYSTEM. works perfect
    Sophomore Member UltraRS's Avatar
    Apr 2009
    Riverside/B.R.
    Did it on my BBC with this http://www.pertronix.com/, part # ML-189. Worked great. No problems for the last 8 years.
    I added the pertronix unit a couple of years ago with no problems yet. I have the dual mallory dizzy also. easy install. Ive had water in the dizzy (condensation) and I also had my kiddo turn the key to on without me knowing when it was stored and it was on for god knows how long since I had two batteries. I would guess prolly a month it was on. Nothing was wrong from that deal either. If I had an open engine compartment I would personally run a hei. Hei gives you a hotter spark. Pertronix is giving you an electronic dwell. Basically just a hall sensor I think. Pertronix unit is the cheapest route and would be the choice for enclosed compartments. A marine hei is spendy.
    If you want to spend a ton of money and have crap buy MSD, and carry a spare box from them too.
