Hot hot hot
Results 1 to 14 of 21
Hot hot hot
    Senior Member Deweydaddy's Avatar
    DBN./DBN HTGS. Michigan
    Default Hot hot hot
    Hi Guys. Had my first outing yesterday with my new boat. Really have to learn to look at my gages more often. Well when I got near shore, I did a couple bump starts to get my heading straight. Thats when I noticed my water temp was around 210-220. Made it to shore, took a little break. About 45 mins. later took it out and it seemed to run around 170-180. Was told it has a 160 stat in the boat. Also no weeds found in the intake. Is this something to worry about? Boat ran strong, really nothing to compare it to, its my first ever jet boat. Big block Ford, alum. cobra heads, solid roller cam. Mostly worried about temp. Thanks
    Senior Member The Violater's Avatar
    Quote Originally Posted by Deweydaddy View Post
    The water in Mich is still cold everywhere, jets pump a ton of water, you should have trouble getting it to 195 right now. You definately need to look into it............
    / The Few The Proud TheBlown
    Quote Originally Posted by The Violater View Post
    Any ideas where to start? Hopefully this weekend get it out again.
    Ladera Ranch
    Whats the plumbing setup? Headers/ logs, O/T or T/T? What kind of pump is it? Does it really have a thermostat?
    El Cajon, CA.
    As the old jet boats were built when they were new they didn't use thermostat's at all. Nowadays there are a hundred ways to plumb a boat so we need to know how it's plumbed to go any further.
    Morgan Hill
    I'm gonna venture a guess, the stat kit has the spring above the stat missing, not enough pressure differential across the block
    GT
    GT
    riverside brawny's Avatar
    check water valve to make sure its open enough.
    160*-180* is not bad when running hard,
    however when you run hard for a time and then
    slow the boat you'll notice the temp. start to rise
    from less water cooling the block(this is normal).
    Quote Originally Posted by brawny View Post
    Right now in Michigan it would be hard to get it to 180 even after running hard and then idleing............. agreed the temp will jump up about 20 to 30 degree's when idleing after a hard run, however the weather has been cold here all spring, the water temp is only 50 degrees almost everywhere right now. When the temp's soar to 90 and 100 in July Aug. he will really run hot if he's at 220 now after a run.................. gotta be addressed and fixed ......................
    Check the sea strainer for grass, gravel and such, if you sucked up it will be caught there first. Also when the water stops pumping, the temp rises, this being an open system, the discharge is reading the temps. When the engines shut off it heat soaks, warming the water to the block temp. Always let your engine cool down after hi performance runs, this helps cool the engine and oil. Good practice, is to always watch your gauges, doing so will prevent minor problems becoming major problems.
    Sep 2008
    Yuma, Az
    At 95 degress, I have a hard time getting it to 150*. How long has the engine been in without being rebuilt or properly flushed. If the plumbing it fine, then I'd say you have a lot of sand or garbage stuck in the motor and or lines. Even in the hottest days at 110* plus, I've never seen my motor close to 220*.
    boatless....
    Assuming it has a STG "jet boat/ double stack/pressure bypassing "T" sat set up" , it should still run consistantly around 160*, most jet boats out there with out that set up will barely get off the cold peg on a hot day. Pictures of the "plumbing" would be helpfull . A jet without the Thermostat setup that runs over 120 to 140 (in warm water and weather) and has no "blockage", restrictions or obstructions could have developing jet pump issues Tom
    Diamond Bar, Big River
    Post
    That's the voice of experience right there. He's fixed a lot of boat owners problems thru his shop. One would have to ruin many engines to gain that much wisdom lol. First follow Toms recommendations. Then look to see if the genious that plumbed it left any old water flow control valves in the system. If there happens to be any Gate valves remove and discard them as they usually corrode and stick partially or fully closed causing lots of greif. I use ball valves in my systems to control water temp and flow along with a water presure regulator that doesn't restrict flow volume. It's worked very well now for over 5 years without issue and i flog my big inch chev. like the wanna be circle racer that I am every time I go out. haha Good luck with that blue oval.
    Santa Clarita
    What does this mean?????
    Southwest corner AR
    Mudpumper, I think he means start and kill it a couple of times!
    WT
    WFL Crew!!!
