Marine carb VS Street carb?!?
Results 1 to 14 of 23
    Default Marine carb VS Street carb?!?
    I heard that the only difference is the curve overflow pipe on the marine carb, is that only that or there is something else??
  2. #2
    Morgan Hill
    Quote Originally Posted by Glastron24css View Post
    For the most part.....
    That being said, there are tuned differences that are not phisycally visible.
    Jetting, power valve size, if vacuum secondary, the vacuum spring rate, yada yada yada...
    But just because the vent tubes are correct does not make it USCG approved, it needs the tagging for that.
    GT
    GT
  3. #3
    supposed to be seals on the throttle shafts too...
  4. #4
    Just curious if anyone has (or can cite) the actual "statutes" and or sections of the "law" (Coast guard or otherwize) regarding what exactly defines a "marine carburators" as well as a multitude of other parts and pieces , as they apply to these boats of the 70's 80's etc Enjoy seeing them posted or referenced here in black and white Tom
    BTW holley J tubes are hard to come by but can be found with a little internet search effort
  5. #5
    Morgan Hill
    Tommy, you don't even want to go there...I was a board member several years ago and would just provide field input to the board for actual real world findings, there are no one set of regulations for anything, every single SAE approved component has it's own set of specs.
    For instance, you cant expect a Carter AFB to have the same marine modifications as a Holley...
    To get an idea of how vast the SAE spec system is here is a link for ya... you can order the manufacturing version of each spec online, at a cost of course....
    http://engineers.ihs.com/collections...-jseries-2.htm
    GT
    GT
  6. #6
    GT
    My point exactly , can never get a straight answer or interpretation from anyone I ever ask including Harbor and Nav and most Rangers (with the exception of some of the component manufacturers) . They (the powers that be ) generally seem to be looking for saftey equipt (this is a good thing btw ) and Mufflers , not at Starters ,Alternators and carbs etc etc , Hey does Enderle make a Marine approved "Hat" and how is a marine blower different from a "door slammer model"
    and heres some food for thought , I suspect that most marine starter "malfunctions" (sparks that become bilge ignition sources) are not caused by the electrical issues but rather the starter pinion striking the flywheel on engagement !
  7. #7
  8. #8
    Interesting Read Thanks Bud !
  9. #9
    Avondale,AZ.
    We stock the "J" tubes, but peeps usually never ask for them..... TIMINATOR 623-877-8553
  10. #10
    Banne'd Cobra1's Avatar
    I think it's all about the $$$$$$$$$$$$$$$$$$$$$$$$.
    Look at all of the old boats still on the water, made out of old "junk resin" compaired to todays standard of resin. Gotta have this gotta have that.
  11. #11
    Alamogordo NM
    Quote Originally Posted by Cobra1 View Post
    Some of it is about safety, but much has to be about the dollars and (non)cents. It is Just like the National Electrical Code. The 2009 edition requires tamper proof receptacles in bedrooms, bathrooms, dens, living rooms and dining rooms. I know the Pass and Seymore guy that was one of the lobbying partys on that code. He said it was all about higher profit margin for manufacturers and inspecting agencies (i.e. the state, county or city).
  12. #12
    I'm in the coast guard...I have a demon street carb. on my jet boat haha. I dont know anyone at my station who would actually give a citation for that, but we mostly deal with outboards here. Also a lot depends on your attitude
  13. #13
    JPB is right about tagging for "MARINE USE" I have a holley 650cfm spread bore in my garage that came off a merc marine Motor from the factory and it doesn't have a tag but I will admit it worked real well on my gen 5 till I made changes!! If anyone wants it I will sell cheap. Yes it has the J-VENTS. M
  14. #14
    Shell Knob, MO
    The marine have hard anodized or billet rotors. Most door slammer blowers don't.
