Water pluming for jet boat
Results 1 to 14 of 22
    Default Water pluming for jet boat
    Hey guys im new to the boat scene and im getting ready to drop my engine in and i have a few questions about the water pluming. It has a 557 ford with bassett thru transom headers and a berkley jg jet pump. According to basset i just need a ball valve coming from the jet (also i know i need to plum in the basset valve for the injection lines and install a ball valve coming out of the engine to set what rpm the injection lines supply water to the headers) to regulate how much flow or pressure? Is going to the engine. I have heard on this forum about some people putting in a water pressure regulator and setting it at 10 psi so i dont have to worry about putting to much water pressure to the block. Would this method be better than using the old style ball valve setup???
    You may want to try a search. This has been hashed out quite a bit. I'd throw a pres gauge on there and see if you even need to worry about it. Some guys will tell you to keep it simple(gate valves), some will tell you to get a regulator,some a pressure relief valve, some will say banderlog,ect,ect,ect. Fwiw to plumb it like bassett says the second gate valve goes on the dump line. The more you shut it the sooner(in the rpm range) the headers will get wet. Edit: Ooops I almost left the 4 port thermostat guys out.lol
    Senior Member 4trax's Avatar
    Shawano, Wi.
    Here is what I was told to use and it works great. Alot!!!!! of boats run these.
    I went in and got recircumsized again........I lost 10lbs. & was able to save the lives of 3 children in the burn center.........but it's not my fault they turned out to be dickheads.
    [email protected]
    How would you even begin to plum that. It looks like in your pictures that from the jet you have both the block and thermostat plummed together. Which doesnt makes sense to me because the block should be the in and the thermostat is the out, so it can circulate
    Shawano, Wi.
    Quote Originally Posted by KONABOY71 View Post
    This will help explain it to ya.
    http://www.rexmar.com/page160.html
    [email protected]
    Shawano, Wi.
    [email protected]
    Sep 2008
    Yuma, Az
    set-up is looking good 4trax.
    mine has two lines going to block through manifold then to housing. one line going outboard and one going to headers.
    boatless....
    Jet boat service
    Sebastopol Cal.
    Kona Boy, Check yout PM's. Jim
    Strap on the JATO konajet74's Avatar
    Antioch,Ca
    Here's my setup in my Kona. 2 -10's in & 2 -10's out off the
    thermostat & a Moroso valve (green) w/ a RPM switch to supply
    the header water @ 2000 rpm's. Works awesome....
    Shawano, Wi.
    Quote Originally Posted by konajet74 View Post
    Do you have any more pics of boat and plumbing?
    [email protected]
    where did you get your electric water valve and how much did it cost.
    Antioch,Ca
    The Moroso valve was around $100 & the RPM switch around $45.
    I got them thru Summit. When you consider the cost of the
    Banderlog & HEI converter, over $300, this was a no-brainer!
    Antioch,Ca
    [QUOTE=4trax;700544]Do you have any more pics of boat and plumbing?
    4trax, sure I'll get some more pics.
    Thanks everyone for all your input. I think i found my solution. Im gona run a electric water controler and a pressure regulator just to be safe. I dont really want to pinch pennies on the water setup and ruin a $11,000.00 engine setup because i didnt wana spend another $300.00
