Help me evaluate this Miller project boat.
Results 1 to 14 of 19
    Default Help me evaluate this Miller project boat.
    First off, Hello….new here. Been around a lot of other boating boards for a long time but no info on jets there. Currently own a Fountain 23TE center console.
    I have been looking for a hot rod boat for dinner and sandbar runs. I do quite a bit of electronic rigging and basic maintenance for a number of boaters as a side job and have often thought about taking on a project boat. I recently came across this and can pick it up locally very cheap. According to the HIN it appears to be a Miller built in 1976. Mark III is painted on each side. The exterior of the boat is in excellent condition. The interior has been removed but is available to be restored. Structurally, there is obvious rot in the sub floor and it appears someone poured some epoxy over it at some point. There are several bulkheads under the deck. The first (nearest the cockpit) is cracked (See last picture). There was no obvious damage to the hull itself but further inspection may prove otherwise. I think we can assume the stringers have rot and I would suspect the transom as well.
    The engine is a 460 Ford that is .30 over. The owner claims it runs but the boat hasn’t been in the water for a few years. It has some corrosion from sitting out in the open. It may be a gem or a turd….
    It is a Kentucky boat that has never seen salt and the steel trailer is in good shape seeming to support that claim. He stated he could start the engine.
    The owner states the Berkley jet drive was rebuilt shortly before the boat was stored several years ago. He states it is a brass pump. I know nothing about jet drives and without being able to run the boat, it is the biggest unknown. Cosmetically it looks good although the sealant is goobered all over which makes me suspicious of any work that was done.
    So…..what am I looking at here? If I purchase this boat, it would be with the intention of making it right. Remove and replace the rot. Probably paint or gel the interior since I live in a salt environment and carpet just doesn’t work.
    Lastly, what do you guys think something like this as is would be worth. Say I buy it and it turns out to be more of a headache than its worth....
    The HIN is MLL192440476
    Asking $2,000 but said to make an offer. Its sitting on the side of an obscure side street so I am not too worried about jumping on it.
    Thanks in advance!
    Pardon the crappy cell phone pics.
    Coeur d'Alene, Idaho
    Default Price
    I think for these guys here to give you some good advice, the price the guy is asking would be helpful..
    Quote Originally Posted by Tittyman View Post
    Asking $2,000. Said make me an offer...
    Sorry...thought I put that in there. Tried to get it all in
    Large Member edog's Avatar
    Riverside, Ca
    It looks like the stringers may have lifted? If so you have some work ahead.
    Quote Originally Posted by edog View Post
    I didnt see anything that looked like lift but I assume they are wood cored and given the rest of the interior condition, I would be amazed if they are not rotten.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    5th pic down looks like there is some sort of delamination, but with all of the crap that is "Slathered" on the bottom of the boat, and miscellaneous B.S. strewn about, I would say that there are quite a few other projects around in much better shape for roughly the same $$$$! but that is just my worthless opinion!
    Where are you looking for a project? I think Cyclone knows of a real solid Rogers 19' project boat, I know of a few, just ask about what you are interested in, and there is a boat that has your name all over it out there!
    Todd
    El Cajon, CA.
    Miller's are nice boats with a following of sorts. I think with today's economy you would be much better off buying one that has much less structural damage (floor, stringers, transom, bulkheads). There are just too many real nice boats for sale for cheap (compared to what it costs to build them). IMO
    Senior Member Rain Maker MN's Avatar
    If you love the hull and are prepared to spend a lot of money to make it right again......I would sy do it
    I would never pay $2K for that boat and try to fix it.......You will probably spend another $8K to make itright for you
    Keep looking......for something in better shape
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    If you want to do a project, the Miller hull does ride like a dream. I have that same hull, a bubble deck. Does the motor run? Check the dip stick to make sure there's no water. I'd offer no more than $1500.00 and let the guy know your concerns. I through mine together last year just to get it on the water. I've got to replace the floor in mine as well and re-carpet. This could be a cool project if you aren't too big a hurry to get it wet. Also, have the guy take soem photos of the keel. That will let you know how many times it's been beached and how much glass work you'll need to do underneith. Where abouts are you located?
    Wags
    [QUOTE=GAWnCA;699352]QUOTE] Its a Great bottom overall Dad Miller was a Legend and its a retro program.
    Cash is Hard today so offer a Grand to Fifteen Hundred.
    Plan on all new wood. and as things improve it gets better. I just let a 78 21' Eliminator go for $2,500 had one of our transom drives, full Hyd trim, Mag Impeller, 2 year old Upholstry, and a new Block 460 Block. Storage @ 100 a monthn eats the bottom end out of worth.
    No Longer Recovering 454Rocket's Avatar
    Torrance, CA - Havasu, AZ
    Personally, I'd never do a project boat again... just too much nice stuff out there that can be had at a fraction of the price (and time) of a project of this caliber. I say $500...
    Sacramento, CA, USA
    Sometimes the satisfaction of saying you made it happen is worth the effort. I know I enjoy working on my boats. I've got the Miller running and a Tahiti project that is going to be a hotrod 16' jet.
    Wags
    Salem,Or
    Sacramento, CA, USA
    Dang!! That went quick!!
    Wags
