Need more 460 info
Results 1 to 14 of 14
Need more 460 info
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    Default Need more 460 info
    So I pulled the intake off today and noticed that the intake side on the heads on number 4 was a redish color. What does this mean? all the rest looked the same except that one ....also i was wondering what oil to use to break this thing in once i put the new cam and bearings in? Do you guys recomend using a high volume oil pump over stock.
    Quote Originally Posted by HBInHeat View Post
    #1 Readish like rust ? #2 Shell Rotella (O'riellys) or Torco high additive breakin" and Only use a HV pump with a High Capacity pan (we even use a standard volume pump on Olds even with a big pan) Tom
    ya its kinda rust color. and the thing takes like 12 quarts is that an oversized pan? the motor is outa a 71 mark 3.....im not sure what cam in those stock
    Pics ?? and yes thats an O'size pan and a HP/HV pump would be OK
    Junior Member In Heat's Avatar
    ill try and take one tonight.... its right next to the water port could it have just been leaking a little into that port?
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    not totally uncommon to have a bad intake gasket
    here is a realy shity picture i took w the web cam doesnt show the color but thats the opening thats light rust or red color
    Golden Shores,AZ
    if you can do a comp test and a leak down if all are good put a new intake gasket on it
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    Quote Originally Posted by 78CoLeBBF View Post
    Tell me Jeremy, is that easily accomplished with the intake manifold removed?
    Look at the picture again.
    Im non induced and My turd leaves pretty hard as she sits.
    Golden Shores,AZ
    what does the intake have to do with these test?
    Lancaster
    Now that I think about it, probably nothing.
    I stand corrected.
    However, it may be a little difficult to get the engine up to operating temperature don't ya think.
    Carry on grasshopper.
    Golden Shores,AZ
    Quote Originally Posted by Hallett Dave View Post
    I stand corrected.
    if you thought to hard it's time for a diaper change get a female nurse this time
    Quote Originally Posted by In Heat View Post
    prob just had a leak at the coolant port and some moisture leached over, it happens. if you're goin to a high volume pump, buy a arp,moroso, or milodon oil pump drive shaft. the stocker will snap in 2 on ya
    orederd a high volume today with an arp shaft actually...Im thinkin it was just moister like you said or atleast thats what im hoping it is. now with this oil pump am i going to get oil belching out the breather? Ive heard mixed things from people that have ran them.
