What mounts do the 3 point Fords use?
Results 1 to 9 of 9
    Monroe, WA
    Default What mounts do the 3 point Fords use?
    I thought I had the right mounts for Dad's Sleekcraft, until I tried them in the boat....
    Is there a mount that will fit better, or do I have to fire up the welder?
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    Fire up the welder, thats how I got mine.
    Senior Member Rain Maker MN's Avatar
    That mount will work, I have a similar set up on my boat currently. Should bolt right up to the side of the block, those are the car style motor mounts found in a lot of boats with the old three point style
    Monroe, WA
    What mount did Sleekcraft use I wonder? I know with an Olds motor to use an old 70 Cutlass mount, but this Ford stuff is kinda new to me. Maybe there was another piece that went in there to take up the difference? I guess I can just weld some sleeves in there...
    Malcolm
    75 Spectra 18
    Malcom with the exception of need for a little "straightening" the mounts and pads look right Tom
    Pink Taco Reagan's Avatar
    Santa Clarita, California, United States
    Default ford
    use a early 80's bbc truck mount with a flat piece of metal to adapt to the block, u will need to drill a few holes but mine came stock like that
    Senior Member gregb's Avatar
    Redondo
    I'd also put some spacers on the bolts between the ears of the insulator and the mount on the boat, so when you tighten it down it doesn't "taco" on you, wouldn't hurt to have one in the middle either, like the two bolts that are currently there, yeah kind of a pain, but at least you could put some proper torque on the bolts.
    Salem,Or
    thats simular to what the ones in my tahiti look like, mine have spacers on the bolts between the ears.
    Malcolm you can you the modern solid BBC Three points and use a simple fabbed "shuffle plate" weve done this with good success, call if we can help Tom
