Old Dominator Bowl retro
Results 1 to 7 of 7
    Sacramento area
    Default Old Dominator Bowl retro
    Hello, I have an old style Dominator bowl, the one with the water lubed shaft bearing, and the steering nozzle that is part specific. (only fits the old style dominator bowl), it’s not Berkeley compatible. The flange is too large on Berkeley equipment to fit the Dominator bowl.
    I have machined the dominator bowl to accept a Berkeley steering nozzle. The question is. What is the best diameter to enlarge the exit opening to? I've heard the bowl preforms better inlarged. I would like the transition angle from the bowl to match the steering nozzle angle as much as possible. If I open it up so the plains are the same (so it’s a strait line) I will be cutting into the stators, and I think the opening will be close to 6.25”. Is this too large?
    Any suggestions?
    Thanks for your time, schick
    Shell Knob, MO
    Make it the same size as the wedge gsket.
    Sacramento area
    Default Bowl retro
    Thanks Duane, I have the steering nozzle size figered out, I'm wondering how much to open up the inner dia.?
    I don't any have another split bowl to referance to.
    Thank, schick
    Shell Knob, MO
    Send an email to me and I'll email you back some pictures of how to do it.
    Duane HTP
    El Cajon, CA.
    Shell Knob, MO
    Did you get the picture I sent?
    Senior Member Factory502's Avatar
    we opened my old dominator bowl to 6.25 I would tell how it worked but the boat is still in pieces
