sucked my intake valves??
Results 1 to 12 of 12
    seattle
    Default sucked my intake valves??
    i have an olds 455.
    i know all about olds oiling problems!
    i am on my seventh season since rebuild.
    my question is, what would cause my 455 to suck(mushroom) 4 of my intake valves? 2 on one head and 2 on the other. 0 compression on three of them and 30lbs on the last???
    all the rest have 160lb.
    Massachusetts
    Blown head gasket to adjacent cylinders is a common way. Did you pull the heads off yet?
    seattle
    yeh there off.
    0 lbs on 1, 5, and 4.
    30lbs on cylinder 8
    Shell Knob, MO
    May have leaned out on fuel and the valves got too hot and tuliped. Seen it happen many times, especially on Olds.
    Member wsm9808's Avatar
    Feb 2009
    Heavy load and low RPM along with wide open throttle and no speed gain (lugging) will do it every time. Its real common on carburated engines. No vacuum at WOT and low rpm causes the carb to not have enough air flow through the venturies to draw out the fuel. Engine leans out, things get over heated in the combustion chamber. The intake valves are not designed for the heat spike and they go soft. Then the combo of cylinder pressure, heat, and valve spring pressures "suck" the overheated valve into the bowl.
    Dragging a tube or wake board at half plane will get you as well.
    Replace all the intake valves when you have the heads done, not just the cupped ones.
    Duane Nailed it , common on this motor , high combustion chamber temps , too lean, not enough octane (needs 91 or better) , worse with the 10.25 (higher compression ) pistons Tom
    Monroe, WA
    I ruined 2 intake valves running my Olds lean a few years ago. Back in the Q-jet days...
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    Do you have an Edelbrock Marine 750 Carb on it?
    Engine junkie
    Thermal, CA
    Worn or low valve spring seat pressures will tulip a valve faster than you can shake a stick at it. Very common problem in a marine engines in particular.
    Life's journey is not to arrive at the grave safely in well preserved body, but rather to skid in sideways, totally worn out, shouting"....holy shit.... what a ride!"
    seattle
    Quote Originally Posted by wsm9808 View Post
    thanx, this sounds like me with a twist of under carberated!!
    seattle
    Default heres the deal
    i have been running a 650 double pumper since 2003. the thing was always hard to start. when it was cold i would have to pump the [email protected] out of it to start it. when it was warm, i would have to hold it to the floor to start it. when i would idle around, i would have to give it gas every 30 seconds to keep it from loading up and dieing!! other than all these hassles, cruisin to wot were always perfect(some how???????????) for 6 years, run hard!!!
    i had my carb rebuilt.
    fixed the starting and idleing problem.
    it seems to suck my intake valves now!!!!!!!!
    Monroe, WA
    What jets are in your carb? I'm running 72/84s in my 750 and getting a lean pop at 3500-4000 right before the secondaries open.
    Malcolm
    75 Spectra 18
