You forget all the sparks that jump from the rotor to the cap comtacts 8x every revolution.
If you run a closed/covered engine, you need to run a marine one, which installs little brass flame-stop screens in the back or bottom of the distrib.
People say the cap is gasketed too, but none of mine ever were.
Also, no way in hell do you get any "multiple spark discharge all the way to redline", unless redline is somewhere in the 3,000 RPM range.
Even MSD will tell you that, above arround 3,300RPM, there is insuficient TIME, with crankshaft rotational speeds, to set off more than one spark anywhere close to TDC.
Info to such is on MSD's website,
Also, you only get Multiple Sparking from MSD if you run their Capacitor Discharge boxes (up to arround 3,300RPM), not just from the distributor (I run a Ready-2-Run dizzy, without a box, becasue I don't need/have any use for a box, but could add one if I wanted to, plug right in).
Good luck in what you decide to do, I have a budget too, often a very small one.
