Strait snoop vs droop snoop
Results 1 to 14 of 21
    Senior Member nasty toys racing's Avatar
    Default Strait snoop vs droop snoop
    I have a droop on my boat rite now and was contimplating on trying a strait snoop has any body tried and trued a strait snoop and do they work
    Got Circus Midgets??? BIGAMIST's Avatar
    S.F.V.
    Quote Originally Posted by nasty toys racing View Post
    i have a droop on my boat rite now and was contimplating on trying a strait snoot has any body tried and trued a strait snoot and do they work
    Quote Originally Posted by BIGAMIST View Post
    Damn you beat me to it.
    WTF is a snoop?
    Thrust Whisperer Doc Nozzle's Avatar
    Feb 2009
    Snoops are stoned snoots.
    Quote Originally Posted by Doc Nozzle View Post
    You mean like this?
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    Call Duane @ High Tech Performance. 417-858-8616
    Depending on what you have and what your boat is doing now, a straight SNOOT may benefit your boat.
    Good luck
    Senior Member hotbo's Avatar
    lake Ouachita AR
    i have a straight snoot w/ 0 degree pin angle on my sj,with 6 degree wedge.worked better than any combo i could find.all boats are different.
    if i remember correctly i think they have a test mule you can use to find out
    they also make a 1 with a 4 degree pin angle.
    I have a droop on my boat rite now and was contimplating on trying a strait snoop has any body tried and trued a straight snoop and do they work
    Nasty All "Droop", Snoots, and bowl extentions along with wedges etc in my opinion are hull and ride tuning "tools" whether they be straight or otherwize, different pin angles etc. Duane (Hi Tech straight snoots) has had sucesss with a multitude of different hull and HP applications , we have found them to be more sucessful on smaller lighter boats , we have also been useing the Place HPH nozzel lately with good sucess, nearly all these changes are "experiments" and "applicational" What works on one boat doesn't always hold true for the next Tom
    You mean like this?
    that's just a stoned snoop, he's having to good a time to be snooty
    So Cal
    WHAT?
    Yes tom i allready spoke to duan he said they have had good success with the snoot,what i really whanted to no is if it worked on my boat 21' spectra,im not after handleing as to allot of tweking and time ive spent on my boat it rides killer and takes a set like a race boat,what im after is more mpr if it would make a difference or not thanks
    you're asking a unanswerable question, you're just gonna have to try 1. there's soooo many differences in hulls, no 2 will react the same to a hardware change.my 21ft daycrusier like a short droop, and i did pick up 3mph when i added it, but the hull was runnnin sooo wet before, i knew it was gonna help
    Southwest corner AR
    Nasty, I run a stright snoot HTP! Went through short droop,full droop,and now stright. All performed well short takes a set faster than any full makes it suck the ass end down,and straight gave the best speed! I havent had the time to do all the testing I need to yet! This is on a 19' Spectra 725 HP pushing the envelope! Mine is the 4*pin with 6*wedge! More testing to come! WT
    you have 10*s of nozzle angle from the start? that's a bit much there coby
