Pumping mud
Results 1 to 14 of 21
Pumping mud
    Apr 2009
    Default Pumping mud
    Two weeks ago i ran a shitload of sand and mud through my berk 12jc-pump when trying to reach the beach. Before that the boat reached [email protected], today it only made 67mph, still at 5100rpm.
    I checked the impeller and it is not damaged, (atleast it is not worse than before). Where did my top-speed go? Any pointers?
    you prob trashed the wearring
    No Longer Recovering 454Rocket's Avatar
    Torrance, CA - Havasu, AZ
    5 MPH can come and go with weight, air temp, a lot of things...
    Tacoma Wa
    Quote Originally Posted by 454Rocket View Post
    And it can also come from an extra clearanced wear ring... I would check to see how loose your pump is now.
    ~Brian
    Newton Ks.
    Quote Originally Posted by LuckyDaze View Post
    ~Brian
    Yep, shitload of crap pumped = shitload of more clearance ground into it, and shitload more high pressure water bypassing back into the intake.
    To repair it takes a shit load of time, and a shit load of money, to fix
    lol not sooo bad if ya know how to repair yoself
    Senior Member coonass's Avatar
    Canyon Lake, TX
    Yes did the same to me last year ..............pull'n out a buddy that was stuck on a sand bar ................needless to say had to rebuild pump
    wear ring was shot
    and remember this next time .......................... whatever you are pump'n out of your jet drive is going into the motor so kill it and walk her to a deeper spot
    Member eugene-rus's Avatar
    Feb 2009
    Moscow, Russia
    How would one check the "loosness"? Disconnect the motor and try to move the shaft forwards and backwards?
    Las Vegas, NV
    i thought pumping mud and blowing out wear rings only happened in san francisco
    Quote Originally Posted by eugene-rus View Post
    remove the bowl and then the impellor and take a measurement of the difference of the two. stock meas. on the od of the impellor skirt is7.225 and id of the wear ring 7.250 leaving an ideal .025 clearance. factory tolerance .025-.035. if you have for and aft movement you have a much greater problem.
    The fact that you're still able to hit the same max RPM value tells me that the pump is fine (loads the engine exactly the same as it did before). If the pump has loosened up, the RPM would more than likely increase (a loose pump won't load the motor as hard, thereby allowing the WOT RPM to increase, but top speed will either remain the same or drop due to a looser pump having less efficiency).
    Just my $0.02.
    Senior Member Xerophobic's Avatar
    Calgary, Alberta, Canada
    Just my $0.02.
    Yea thats what I was gonna say too.
    I also still dont buy that a single time pumping some mud/silt will trash a pump like that either. We do far far far FAR worse to our pumps all the time and they just dont show that kind of deficiency of performace. We start our boats in shallow water all the time, even race boats, because we have no choice and they just simply do not wear that way. Sure maybe after a whole season of doing it, but not one time.
    Something else isnt adding up
    Cheers
    Quote Originally Posted by Xerophobic View Post
    Cheers
    Exactly, something else is going on. Did he add a passenger (passengers are worth about 3-5mph)? Did he have more beer or ice in the ice chest? Weight will affect top speed while top RPM remains the same (RPM is only affected by pump load, impeller cut, clearances within the pump, etc etc...not by boat's dynamic properties, i.e. weight, speed, etc).
    Was the diverter set to the same position as last time?
    Too many dynamic variables to mention.
