Bowl Pressure "sweet spot"...?
Results 1 to 14 of 37
    on 3 go..... Slow Burn's Avatar
    Aha - SoCal.
    Default Bowl Pressure "sweet spot"...?
    Where's the best sensor location to measure my bowl pressure?
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    call mpd
    SLOWBURN thats easy call G&S there on top of the game....951 272-6060
    Golden Shores,AZ
    Quote Originally Posted by bob fry View Post
    nut swinger! hey what intake you running in your boat bob
    Aha - SoCal.
    Just wanted a few peoples opinions.
    B1 Racing cs19's Avatar
    really looking for bowl pressure or did you mean intake pressure?
    Even if he's not talking about bowl pressure... where would be the sweet spot on an intake? And what would be a good pressure for a v-bottom?
    Tony
    Green Bay Wi,USA
    depends on what intake is used and other stuff.
    Ok, 1977 Hondo Pantera. Round keel, home made shoe and rideplate () Possibly going to a cut intake for shoe soon, 550hp, super sport loader, berk pump with B cut impeller. Any guesses? Berk intake
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I'm curious about this too for both the bowl and intake, also what size tap 1/4 NPT? (berk suction, berk bowl)
    Senior Member sleekvino's Avatar
    heres where i did mine....
    Quote Originally Posted by sleekvino View Post
    nothing wrong with that.
    1/8 pipe is most common.
    Ok... now what would be a good "general" pressure to look for?
    Hey Tony,
    Heres the CP:
    This is where I used to pull the pressure from. The location near the wear ring shows approx. 8 psi more than this area of the intake:
    I went through several gages before I got this liquid filled AutoMeter. Mounted it on the dash. It's up-side down so I can read it at 105 or so with out having to search. The liquid filled gauge has next to zero bounce. PSI check valves don't work for what you want to do. You need to be able to read the gauge at speed.
    Sleeper CP
    Jon
