Ford distributor shear pin issues
Results 1 to 14 of 35
    Senior Member PRO53's Avatar
    TOMBALL, TEXAS
    Default Ford distributor shear pin issues
    Shearing the dist shear pins on my 521 stroker motor. New motor not much run time. Looked on 460 ford.com, seen issues and possible fixs. Tired of messing with it. Anybody over here ever had this issue? And a fix that actually works? Does anybody sell shims and how do I know how much shim to use?
    OMEGA JET, AND Sanger Shovelnose Hydro
    "DOWN WITH THE SICKNESS"
    AND A LIST OF ONGOING
    bullhead city
    what kind of dist you running
    TOMBALL, TEXAS
    Quote Originally Posted by hihosilver View Post
    Vertex Mag, bronze gear, mech. comp cam, non roller. I dont know if the bronze gear was maybe installed incorrectley or not. Thinking about sending it in and have another gear installed on it.
    mornin george check that oil pump too, a pump that's locking up will do that too.
    TOMBALL, TEXAS
    I have to pull the motor to do that right? Man I proably dont have more than 10 hrs on that motor. Can I just put my drill motor and my oil pump primer on it and spin it?
    Default positon of gear
    height of the gear is critical. you need to set it exactly right and drill a new hole through the shaft for the pin. also, how much oil pump and how heavy oil? look on 460 forum for the correct height.
    TOMBALL, TEXAS
    Quote Originally Posted by OkieDave View Post
    Rotella 15/40, hi-volume Mellings, dual remote filters. Will be removeing the dual fiters now and running a 45 degree or 90 degree adapter and a single filter. 10 QT PAN.
    TOMBALL, TEXAS
    It also had alot of line going to the remote filters. Alot of strain to push oil through all those lines. Maybe that is some of the problem?
    Quote Originally Posted by PRO53 View Post
    yeah, put a drill on the pump and see if it has any spots that are sticky
    TOMBALL, TEXAS
    So if the drill slows down in spots while its spinning? Going home for lunch, yanking the dizzy, then spinning the pump.
    I have a mallory dist. and spun the pin last year on my 460. it was a .125 @ 7/8 long . I bought one @ local hardware joint. Before install I greased the shaft, as some dist. dont have enough from factory. Hasnt happened again so far, but what a buzz kill when it did. Had no idea thats all it was. Thought at first it was the module. Easy fix with center punch and all metal was still in dist.
    Made In The Shade
    Custom Window Tinting
    Shims work, but a major PITA. Really no way to hold on to one, and one slip and it's in the oil pan. You can do it with the timing cover off, but you just have to remember the next time you take out the dist. that it's there and be real careful. If the pad in the block (that the gear rides on) is worn to the poiint this is a problem, it's probably worn unevenly and somehow the surface should be re-machined so that shim has something smooth and flat to sit on. Then you just shim the gear so it's centered on the cam. If someone wanted to get really clever, they'd come up with a Torrington bearing mod for this. I've double pinned distributors in the past. You have to be careful re-locating the gear on the shaft...you don't want to drive the smaller collar at the top of the sahft into the bottom of the dist. housing. With the dist installed and tight, there needs to be a little play in the shaft up and down so nothing is binding.
    I doubt is's oil pressure related, but that's JMO.
    If you have good ford speed shop fords have to be measured to assure a perfect alignment on the shaft, distance from top flange to bottom of gear.
    Senior Member sdpm's Avatar
    CP Sleeper here on the boards was having that same issue. You might want to contact him to see what he did to correct it.
