Where do I get these gaskets?
Results 1 to 14 of 23
    Member eugene-rus's Avatar
    Feb 2009
    Moscow, Russia
    Default Where do I get these gaskets?
    I am about to order some gaskets for my Olds 455. I can order the valve cover gaskets from Mondellos but where do I get these from?
    Default Log to riser
    Are you referring to the logs to riser gaskets? I have always made them. There should be a thin piece of stainless sandwiched between two paper, (gasket material) gaskets. The big issue is getting the risers off with out breaking off the studs in the logs. Use WD40 or Marvel Mystery oil to soak those threads. I would guess the log manufacturer would have the necessary gaskets, if they are still in business. If not, get some gasket material, the thicker the better, and make them. DO NOT leave out the sandwiched metal, or you will have leaks the first time out......Once I get a set to NOT leak, I never take them apart again.......If yours don't leak now, leave them alone.........Ray
    Feb 2009
    Moscow, Russia
    Yes, logs to risers. I believe these are hardin marine. I went on their website and they only have the modern stuff there.
    I wouldn't want to take these apart but .
    Yucaipa, California
    i got them at the local boat shop cheap. The studs can be a pita , i snapped one but nothing the machine shop couldn't handle fixing. If i remember, they're fine on one side, course on the other stainless studs. Good luck.
    Senior Member Futs's Avatar
    Orange CA, Big River
    That was my guess and it looks like I was right......
    Charlotte, NC.
    well it looks like you found your leak.. good job!!!.. I would just use some gasket material as was suggested. If you have the metal peice in the middle you could use that as a template for the other peices.
    that looks like the 4 hole gasket that i buy from rex. check them out at rexmar.com, thats quite a leak.
    Dallas, TX
    Quote Originally Posted by eugene-rus View Post
    Is this not them?
    http://www.hardin-marine.com/detail.aspx?ID=1465
    Feb 2009
    Moscow, Russia
    Hmm, I think I missed that one. Ordered now. Thanks!
    Feb 2009
    Moscow, Russia
    Thanks to everyone for the tips!
    Banne'd Cobra1's Avatar
    I've seen people use RTV, and it last's a long.
    Southwest corner AR
    As was stated earler these two pieces are hard to get apart and I have had to cut old logs off of the riser! Not fun at all! What happens is like a fuesion between the stud and Alu. Be very very careful or you wil be buying new logs or risers! Good luck! WT
    I just noticed in your video that both the logs and risers have been welded! When you get them off and apart inspect the insides for cracks that could put water back into the motor! Check real good on Ex. ports in logs!
    In pace requiescat povertyjet's Avatar
    Apr 2009
    Huntington Beach, CA
    Use anti-sieze on the stud threads and nuts when you re-assemble to avoid galvanic corrosion.
    p-jet
    Eugene ,those gaskets are in stock and ready to ship , just 249.93 rubles (about 8 bucks a pair) Dosvidanya Tom
    ps yours look to be Very early Edelebrock type (3 equally spaced holes) not the standard "4" like Harmon, Hardin,Gil, Panther etc etc
