455 olds
Results 1 to 9 of 9
455 olds
    seattle
    Default 455 olds
    where do i find a high performance fuel pump??
    Junior Member 86'd's Avatar
    Vacaville, CA
    Yucaipa, California
    Quote Originally Posted by 1975sleekcraft View Post
    If your old mechanical pump is the one that has the inlet, outlet, and vapor/overflow line going back to the carb i'd like to take it off your hands (if it's still working) Mine is 35 years old, i'm sure it's running on borrowed time.
    1992 Eliminator Daytona 21'
    Apr 2009
    SW Ohio
    Does anyone still sell a mechanical "marine rated" pump for 455 olds? The engine I just bought has a mech pump with the outlet - inlet - vapor port configuration but I think the diaphram is shot because the crankcase oil has a strong gasoline smell and seems thinner than it should be. It could also be leaking from the carb so im not sure. My other engine (also marine and just as old) has the automotive style outlet - inlet only configuration so who knows if it is really necessary.
    Is there a good way to pressure/vacuum test these old mechanical pumps? Just pressurize each port to 4-5 psi and see if it leaks over time?
    Junior Member 74miller's Avatar
    Logan, UT
    You could hook your vacuum guage to the inlet side of the pump and crank the motor over, should pull a good vacuum in the 13-16 range.
    Monroe, WA
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    seattle
    Quote Originally Posted by Tahiti Boss21 View Post
    it is only 2 seasons old and it has an inlet, outlet, and one with a rubber cap on it? so this is a vapor overflow?? where on the carb would this be plumbed???
    tahiti boss, mine is automotive. can be bought new at most part store. this is why i am inquiring about maybe a higher output pump??
    malcom, what did you finally end up runnin for a fuel pump???
    Apr 2009
    SW Ohio
    Mine is plumbed (Q-jet) to a port at the rear top of the carb, just below the flame arrestor. It appears to simply vent to the area just inside the flame arrestor by the rear (larger) upper butterflies.
    Monroe, WA
    I still have a standard parts store variety on my new boat, but I have the RobbMc off my other 455 just waiting for this one to give me any trouble at all.
    Malcolm
    75 Spectra 18
