holley proform bodies
Results 1 to 7 of 7
    seattle
    Default holley proform bodies
    can anybody explain how you can take a 650 holley, buy an 850 proform body, and it becomes an 850???????????
    these kits dont come with bigger butterflies....(or do they)???
    as far as i can see------bigger venturies, same throttle plate?????? = bigger carb?????
    please help???
    trying to make up my mind on what and which carb to buy, or upgrade mine??
    thanx for any and all help!
    Kingman/Golden Vly, Az
    Quote Originally Posted by 1975sleekcraft View Post
    please help???
    i dont know the answer to ur ???, but, i do know that people have taken the 660's & put the 850 base plate on them & made them work fine...depending on ur application (motor, usage, etc), i would either upgrade the 650, especially if its a DP mech sec or shop for a 700DP or 750DP mech sec...both work fine on stock to mild motors...i have a 650DP mech sec modified by myself on a Edel air gap manif on a mild BBC 427 that works pretty damn good for my purpose...just my .02 cents
    FastRat
    Senior Member OUTLAW HALLETT's Avatar
    SHASTA LAKE CA.
    as far as i know , they wont ,, you can go from a 650 to a 750 with just the bodie change,, the way it works is the baseplates are the same on both, if you look at the top of a 650 bore compaired to the bottom , you can see the it is different, the bore it tappered,, on the 750 it is the same all the way through ,, i just put 750 hp bodies on my old 650s
    Yes but what about the emoulsion tubes in the metering blocks? Wouldnt they have to be changed too?
    Southwest corner AR
    please help???
    I know it is cheaper to change bodys out but IMO you should look for a new 750 Holley stright out of the box! Problem solved! WT
    WT
    WFL Crew!!!
    Default works
    Corndog just did Holley's kit to upgrade his 650 DP to 750s. Paid $135 a kit. Says it works very well. Has all gaskets and needed parts
    Monroe, WA
    The standard DPers use the same throttle plate, so yeah it's all in the main body.
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
