how much boost can you run
Results 1 to 14 of 22
    Senior Member nasty toys racing's Avatar
    Default how much boost can you run
    how much boost can you run on pump gas 496 blown intercooled
    So Cal
    not much ... 8 psi?
    Depends on what pump gas (premimum I would suppose), altitude, heat, your blower, etc etc etc
    there are a lot of variables that go into that question ... almost too many to answer without a lot of information
    Senior Member Green w Envy's Avatar
    Edmonds, Wa
    run pump gas with water meth injection get a bit more boost.
    Darin
    1471 under driven 20% at 5 # rite now,i was told i could run 10 to 12 on pump gas as long as i had 20 to 25 pounds of water preshure in the block
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Quote Originally Posted by nasty toys racing View Post
    Comp ratio?
    Forged internals?
    Are you data logging?
    So Cal
    I wouldn't go over 8# on pump gas ... you could up it if you ran a 50/50 blend with 110 octane, gives you a 100 low lead blend with burn control properties.
    Problem is that pump gas is such a poor performance fuel and is so inconsistent with engine temperature changes.
    Blower motors & pump gas are not a good combinations IMO ... especially with a blower the size of yours.
    FAT GUY IN A TPR STEALTH NO REGRET$'s Avatar
    MENIFEE . CA
    boost is not as important ..as your final compression ratio .
    your static com. + boost = your final...... an 8 to 1 motor with 8 pounds of boost = 12.4 final com. ..BDS AND OTHERS recommend that you keep the final to a maximum of 12.2 to 12.4 on pump gas. you can read everything on the BDS web sight.http://www.blowerdriveservice.com/faq.php
    "Life's tough......It's even tougher if you're stupid."
    -John Wayne
    ..JUST HAVING FUN..
    . . . .SIPPY CUP RACING. . . .
    MySpace URL:
    http://www.myspace.com/dp734taj
    So Cal
    Quote Originally Posted by NO REGRET$ View Post
    Darrin is right ... but there are too many other things that determine if pump gas is going to be okay. I would be more worried about the stability of the pump gas itself along with the temperature and altitude in which he's running.
    Bottom line, I wouldn't be getting after it with a 1471 and pump gas. I would keep the boost low.
    Much cheaper to run Av Gas (which I don't usually support either) or a blended pump/race gas instead of learning the hard way and hurting your engine from a bad tune up.
    Senior Member Tony Skagen's Avatar
    598ci 9.3-1 comp 1471w/intercooler and water/meth injection I run 10psi of boost on pump gas 30*timing.
    Quote Originally Posted by blown glass View Post
    you ever worry bout that water/meth tank goin dry? we put a methanol plate under the blow thru carb to hold off detonation alil more, runnin 16lbs on pump gas, or gonna try to anyways intake temps will be below 100* so it should be doable.gonna hobbs switch the methanol to turn on over 10psi, wether its running 16lbs or 30lbs.
    I use a safe injection box from snowperformance that will trigger a retard box to pull timing if flow stops under boost.I have used this system on a few motors with very good out come!
    spokane, WA
    Tom,
    blown Glass has one of the most bitchen set ups I have seen and really knows his shit!! That beast is making around 1200 on only 10psi and pump gas....!! pm him for a safe injection box and never worry about it going dry on ya!
    I will try and call you this weekend Tom!
    Travis
    spokane, WA
    If your intake charge temps stay below 100, 16 psi on 92 will be easy!!! I just love turbos......
    Travis
    Senior Member smitt19's Avatar
    carmichael, ca
    Default pump
    I've run 10 lbs on pump for some time now 8.5 intercooled checked 3 different times never saw any detonation, called boost power not log ago, they said there building there motors with 9.3 and running them on pump, cam will be a factor of course he was talking like 115-116 center line
