I cant get my boat to start.....HELP!!!!
Results 1 to 14 of 24
    Member TooSober's Avatar
    Lake Forest, ca
    Default I cant get my boat to start.....HELP!!!!
    I have a 454 big block. the last time i drove the boat it was miss firing do to the distributor cap coming loose. i have replace the cap, battery, and also the altinator. I cant even get the gauges to come as well. when i was disconnecting the battery i could hear my speakers making noises. when i try to start the boat i get NOTHING!!!!. I have followed most of the wiring connect to the key ignition and dont see any issues. Any info would help a ton as i am trying to save money and also trying to take the boat to the river for the fourth of july. Thanks
    seattle
    Default negative
    sounds like a loose or not hooked back up, ground
    Takes Spark and Fuel , call if I can help you diagnose this Tom (check Pms for cell)
    Senior Member Futs's Avatar
    Orange CA, Big River
    Check for a fuse under the dash, or check the 50 amp breaker at the engine harness if you have one.
    Lake Forest, ca
    Quote Originally Posted by Homez View Post
    did you hook all the wires back up to the starter- what kind of boat/ drive?
    Yes I never unhooked them. Its a 1994 hardin jet boat
    Senior Member Ol Man's Avatar
    this is my guess
    Start with fundamentals , put a plug wire close to ground and Crank the motor (should be a good strong spark , then work the accelerator pump on the carb , fuel should be present if you got spark and gas and a strong battery the boat should fire , once more I'm around (between "shops") today if you need help Tom
    Sacramento Ca.
    Quote Originally Posted by TooSober View Post
    When you say you "try to start and get nothing" do you mean the starter does not crank over? or does it crank but not fire? If all you did was replace a distributer cap be sure to check the rotor is in proper position, and did not get damaged when the cap came loose. If you dont have spark my guess is thats where your issue is gonna be if the boat ran before hand. What kind if distributer??? Hei or points...
    I ran an Hei distributer in my 59 chevy and a few times when i would connect and disconect the battery i would get a power surge and actually fry the ignition module within the distributer. Check there for sure! They are cheap and a good place to start if not getting spark with an HEI.
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Posts 5, and 9 are were I would be starting. Also use a voltmeter and check for voltage at the coil, dist/points, ignition ect. If you don't have a multimeter go to autozone and get one. Chase the voltage and you will find the problem.
    Wanna be
    Apache Lake Monger AZKC's Avatar
    Tucson
    Get a test light and check the junction block where the main power wire that brings power to the junction block either from the battery or a wire from the starter. It should be hot(power) all the time. then check the igniton wire when you turn on the key it should be hot. Also ck the circuit to the solinoid that when your cranking its hot.
    With your gauges not moving when you turn the key sounds like you had something go wrong when you swapped the battery.
    Senior Member GRoper's Avatar
    sounds like a loose ground.
    The HMFIC HWLaser23's Avatar
    fontana ca
    if you turn the key and you get nothing, no click, no crank, no nothing i recommend hitting the starter and solenoid with a hammer. the solenoid may be stuck in the open position, do this while someone is turning the key. this is how i get big trucks started they have hung up starters. 8 times out of 10 it works. you can also get a screw driver and bump the starter by grounding it to itsself use the screw driver to touch the posts on the starter at the same time. if the starter bumps or the motor starts you know you have a prob between the starter and the ignition. that will help narrow it down to and electrical problem
    BLACK SMOKE DON'T MEAN ITS BROKE
    Quote Originally Posted by HWLaser23 View Post
    Shade tree at it's best.....
    fontana ca
    it may be shade tree but it works. IMO its the best way to diagnose a bad starter with out paying a mech a 4 hr minimum elec diagnostic cause in a matter of 15 min the mech will do what my shade tree advise was, to isolate the starter from the elec sys. then you risk him giving you back your shizz and saying i got it started and after i got it started i shut it on and off a few times to make sure its good. all the while hes handing you a bill for 4 hrs at 120 if its a merc shop and you have to pay it and hope the prob doesent come back. but if you figure the prob on your own and you now know the starter is starting to hang up then you can go to your mech and get the starter replaced for half the labor and parts. not to sure about anybody else but im all about saving money where i can
