Intake set questions
Results 1 to 6 of 6
    Lake Palestine Texas
    Default Intake set questions
    I have a 1987 Baker tunnel with an early Dominator pump and I am wondering about the set. Here are a few pictures.
    When I lay a straight edge along the bottom of the hull the leading edge is almost an inch above and the shoe is at least 3/4 of on inch above.
    I just upgraded to an 800 hp engine don't feel I am going to see max gains without some major work on the pump.
    I am new to this and did some searches but it looks like I need some expert opinions on this specific setup.
    What are your thoughts?
    Thanks, Alan
    Nice boat one the top side I would definitely
    find a shop that knew what they're doing and get that intake reset. I can't really tell from the pics, but do you have a delaminating problem also?
    #55
    It's paint flaking. I looked that over real good when I found it. The bottom does need some serious attention.
    Alan
    Like Outlaw said Thas a Bitchen Boat !, The "repairs' around the intake area suggest some leakage and thus the neccesity to remove and reset no matter what Call if we can help , we do a lot of these Tom
    Clovis, Cali
    I'm no expert and I might be seeing it wrong. But, doesnt that look like flat keel intake ? Maybe the hull had a flat keel and someone added the round section. That might explain why the intake looks so high. Is the keel flat or rounded on the inside ?
    Quote Originally Posted by propless View Post
    That is one of my concerns, I did not want to voice it to find out if anyone else saw it. I don't have any history on this hull other than it is rumored to have been a drag boat at one time. The inside is contoured but not as much as the bottom. Is anyone familiar with this style hull?
    Alan
